Question about JVC AM FM CD DET FACE CAR STEREO
How to reset security code for a 1997 mercedes benz c230
Changed my battery on 1997 mercedes benz
Posted by ray butler on
Nicky Bell
    Scholar:
  • 94 Answers
Check the manual for the security code for your vehicle. I'm pretty sure it's a 5 digit code. If you locate it, enter the code into your stereo. You may have to take it to a Mercedes dealer if you cannot find it. If you do have to take it to the dealer, pull the radio out and get the serial number from the side of the radio, the service tech will charge you big bucks if you make him do it. I hope this helps =)
Posted on Nov 09, 2013
Has one code po507, won't reset, won't start, but it will run, if I spray starting fluid in the air box
Search Results
    P0507 Mercedes-Benz - Engine-Codes.com
    engine-codes.com/p0507_mercedes-benz.html
    Possible Causes and Repair Information for P0507 Mercedes-Benz code. Learn what does P0507 Mercedes-Benz means? P0507 Mercedes-Benz Idle Control ...
Aug 01, 2015 | Mercedes W202 C230 C280 Rear View Mirror...
2004 Mercedes-Benz C230 kompressor warning gauge Battery / Alternator needs to be service.
check your volt gauge on the dash. if it's working properly, then your car is throwing a bad code. if the battery looks as though it's taking more than 14 volts, or less than 10, you have a problem.
Sep 17, 2013 | 2004 Mercedes-Benz C230 Kompressor
1998 C230 Mercedes factory stereo reset instruction
you can try removing the negative cable from the terminal on the cars battery for a few seconds (but it will reset time clock as well)
Jun 07, 2012 | 1998 Mercedes-Benz C-Class
Reset radio code mercedes c230 how to
i want tape code ?benz c230 tape model cm2299 srial no.2299w0926802b
Jun 04, 2012 | 1998 Mercedes-Benz C-Class
Radio code fro 1998 mercedes c230
my 1998 Mercedes remote, stop working. I've changed the batteries in the remote and changed the car battery.. but my car still will not engage the key to start.. what do i do??
Jan 26, 2011 | 1998 Mercedes-Benz M-Class
How to reset the service light on my 2006 c230 sport
disconnect the battery for 30 sec. then reconnect. this clears all trouble codes and will turn that light off.
May 01, 2010 | 2007 Mercedes-Benz C230 Sedan
I have a 1997 mercedes c230 i change the computer it wont start do i have to take the computer to reprogram
no check fuses, if youre gages work or jump when you turn key .....computer ok ...try to disconnect battery for an hr or two maby over night
Dec 12, 2009 | Mercedes-Benz C230 Cars & Trucks
Spare key for c230 mercedes benz
does it have a chip in the key ? if not any locksmith can make you one
Feb 23, 2009 | 1997 Mercedes-Benz C-Class
JVC AM FM CD DET FACE CAR STEREO Logo
172 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
