Lenovo IdeaPad Z560 Notebook Logo
Anonymous Posted on Mar 23, 2013
Cannot adjust brightness in windows 8
Installed windows 8 pro. Brightness is full and can't reduce it
Jeiwfugppd Gbcmhrukpy
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Feb 17, 2016
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
0
Helped
2680
Points
18
Recommend you guys a good site to get cheap and genuine product keys for windows: www.vinhugo.com, all versions of windows keys can be found there.
Christina00
Level 2:
New Friend:
  • Expert 33 Answers
  • Posted on Jan 23, 2015
Christina00
Expert
Level 2:
New Friend:
Answers
33
Questions
0
Helped
9282
Points
159
Hey, believe me, you are not the last one who have this problem. I also had this problem same as you last week, and I google an instruction from the Internet, tells me open Control Panel>Hardware and Sound>Power Options>Change plan settings. This worked for me well. Don't know whether it works for you or not. But you can have a try. Good luck! By the way, here's what this page shows me:
How to Change the Brightness of Screen on Windows 8 1 FixTips org
Kevin McFarland
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 21 Answers
  • Posted on Mar 23, 2013
Kevin McFarland
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
21
Questions
Helped
3731
Points
57
Your laptop button functionality will not work until you install the drivers necessary. Check online for the drivers and make sure that all of your drivers are installed in device manager. To get to device manager, right click computer and click manage. In the sidebar, go to device manager. I'm not quite sure if windows 8 has a software slider... it should be under power options where you can adjust the screen brightness to save battery. Good luck
  • Anonymous Mar 24, 2013
    i have installed everything but not working.Please provide me solution and it will be highly appreciate.
2answers
When I update Windows 8 to 8.1 Lenovo Z500 Series Laptop than My computer Brightness is decrease?Please give me solution
Try this:
https://forums.lenovo.com/t5/Lenovo-P-Y-and-Z-series/Z400-Adjusting-the-Brightness-in-Windows-8-1/ta-p/1303113
Which operating sysytem is compartible with my dell inspiron N4050?
If you can't go further down your probably at your lowest brightness level
There is limited option to adjust brightness
Read at http://support.dell.com/support/edocs/SYSTEMS/ins4150/en/i4150_om.pdf
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.)
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor.
Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
Brightness and contrast symbols
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 • HP...
How to adjust screen the brightness on HP TouchSmart 520-1100
To adjust the brightness you press the Fn key on keyboard and simultaneously press F10 to reduce brightness. Press Fn simultaneously with F11 to increase brightness.
I installed Windows 7 Pro on my compaq 615 laptop, but since that time i have a very low brightness problem on my screen, I cannot adjust it to maximum, Thanks for helping me....
Ensure you have the correct drivers installed and using Fn and F7 plus looking at the Power settings, Adjust Brightness settings adjust as you require.
2helpful
I would like to reduce brightness on my ASUS VH242H
Actually, the problem isn't with the drivers. Right click on the battery icon in your system tray. Select "Power Options" (NOT Power4Gear eXtreme). On the right panel, select "Adjust the display brightness." Then, select "Change advanced power settings." Scroll down and open up the "Display" box. The options that are affecting your screen brightness on battery are "Allow SmartDimmer to reduce my brightness after," "Have SmartDimmer reduce my brightness by," and "SmartDimmer full-screen video mode." Playing with the percentages in these boxes will affect how your screen brightness adjusts itself. To get my screen to stop re-brightening itself, I changed "Allow SmartDimmer to reduce my brightness after/ On Battery:" to 100%. I then changed "Have SmartDimmer reduce my brightness by/ On battery:" to 0%. Finally, I set "SmartDimmer full-screen video mode/ On battery:" to Maximum Power Saving. This should solve your screen-rebrightening problems even with the 163.44 drivers (I use those too). Please Rate.
Thanks, Anand Fixya
2answers
Screen Brightness
windows 8 to 10 have the brightness control in the action center or power settings or look in the charms bar if your using windows 8 or 8.1 (note: if brightness doesnt change it maybe due to the OS not knowing how to change the brightness let me know if that ends up being the case)
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
