Do the batteries charge? Are they charged? The green indicator normally is the status signal that the battery is charged and the red indicates that the battery needs charging or is charging. If you plug in a charged battery, some chargers will flash red momentarily then go out. This is an indication that the charger checked the battery (red light) and if the charge is good, the red light will go out. I hope this helps you.
if you turn the freezer off for some time then on again the red light has to come on as an indicator for high temperature it goes off by itself when the freezer attains the required temperature according to the thermostat settings ,that is the lower the settings the faster the red light goes off. the orange light indicates super cooling and the green light indicates power supply.if you turn the two lights off and the freezer still works without the green light on that means that the bulb for the green light is faulty and you don,t need to worry
The modem cannot get a signal from your service provider. The DSL light is an indicator if your modem is communicating with the network of your service provider. DSL light should always stay solid green. Try contacting your service provider. It might also be an indication of a bad modem.
When a set is powered up, there are internal checks that are performed. The initial green light indicates that power has been applied. The flashing red light indicates that a problem was found that is preventing the set from functioning properly and it has shutdown to prevent further damaeg. If you can supply the model number, I may be able to provide additional details. Also, check to see if the flashing red light has a pattern. Quite often the pattern will indicate what problem was detected.
ok on the terminal block looking in from the back you have 3 terminals on your new cord there is a Black a red a white and a green the Black goes to the far left terminal the white goes in the center terminal the red goes on the left terminal the green goes to gound or a green screw on the back of the unit if there is not a green screw then use the screw that holds the cover plate on
