Cars & Trucks Logo
peter Posted on Mar 23, 2013
Vw golf mk4 my rear passenger door willnot open with central locking key system. i can't even open it from the inside, pull the door handle and the lock pin rises but door won't open. i believ
Philip Wright
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Oct 28, 2013
Philip Wright
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4564
Points
6
This worked for me on 2008 Mk5 Golf, after the rear passenger door would not open fro outside or inside.
Hold the inside door latch open and keep it extended, then with the key fob open and close the door locks (still holding the inside latch open). Keep locking and unlocking the door, then it made a kluck and it released.
5 Related Answers
Anonymous
  • Posted on Aug 21, 2009
SOURCE: Central locking issue on my Land Rover Discovery II 2003
Does it open from the outside once you have manually opened it from the inside.
Anonymous
  • Posted on Aug 29, 2008
SOURCE: central locking problem
i had a similar problem on the front doors .after taking it to a garage for a quote £ 180 i read into it and there are micro swithches in the locks so with a gentle tap with the hand the door unlocks . hope this helps it saved me the money
Anonymous
  • 34 Answers
  • Posted on May 11, 2009
SOURCE: volkswagon Golf Mk4 rear door handle locked!
just take time and a light. open down the rear seat and look to see where the screw is to turn on and off the child lock then try and turn it to the off position. may be remove the door rubber as well to give more room. just give it time u bwill manage to get it
Anonymous
  • Posted on Nov 26, 2009
SOURCE: My VW Golf mk4 does not respond to
Join http://uk-mkivs.net/ theres loads of info on this and other things you can fix or mod and the banter is just great :)
If your a hands on kind of person theres a link on here how to fix it yourself with just some soldering needed cjrobbo
http://forums.vwvortex.com/zerothread?id=1542461
Anonymous
  • 111 Answers
  • Posted on Jan 31, 2010
SOURCE: my golf mk4 tdi boot wont open atall
I take it this a normal key not a electronic one, normal key has teeth,get some powered graphite from the parts store,hold open the little key entry door on lock,spray in graphite(plenty),move key in and out of lock until smooth,more graphite,put key in lock, gently turn key side to side,more graphite,work the lock,everything should loosen up, never use liquid lubricants on locks
2003 VW GOLF REAR door wont open
The rear door lock actuator has failed in the door locking unit this is a common problem you can manually unlock the door to replace the latch if you didn't have the deadlocking on if you cant try pressing the locking button twice so when the car is locked the flashing red light is not blinking ie off on the drivers. Doing this usually causes the faulty lock to release the dead locking so you can pull the inside handle to unlock the door.
HI, I have a 1998 mk3 VW golf, 5 door, the problem I have is the passenger rear door can only be opened from the inside but will not open from the outside (so it isn't a childlock problem) in addition to...
Sound like different problems. In the matter of your rear passenger door, you may have a loose or broken cable which connects the handle to the release mechanism.
As for the driver door, you may have a bad cylinder or complete door door latch.
Hi. the exterior door handle on my mk4 golf came out, I have tried different ways off getting it back in, and so i did after i took out the lock mechanism, but then a hole new problem... my central locking...
just go and double check, you probably pulled out the plug from the lock. maybe you didnt know or you forgot to put it back, no power on main door locking system.
Locked out of my golf mk4
Try the passenger front door with the key.Many cars will open this way good luck.
Boot on vw golf mk4 wont open
have somebody pull up on the trunk while you press the button inside
1helpful
CEntral locking problem drivers door, VW GOld PLus
Actually they area vacume/preshure opparated system.... now if fitted with this crazey system bear with me!!!!!
Open the boot, pull back the lineing to reveal the off side rear lamp cluster, underneath the cluster you will see a black box with a plug and a plastic preshure pipe going to it (this is the vac- air+ preshure pump and electronic control unit.
Now what happens is this the seal on the back light cluster leek rain water in after a while, and guess where it goes? Yes thats right all over and inside the box where al the electronics are! Fantastic ! any way solution is easy just take the box out....take it in the house open it... tip the water out! dry it out in the airing cubard or hair dryer e.t.c. put the lid back on thats it (GOODTHING REALLY SEEN THE PRICE OF THEM?) oh! forgot to say it is in like some grey polystirine in the car to stop it banging about!sugest you re seal the lamp unit with some RTV silicone sealer (Better than the manufacture seals) OH YES THAT BOX ALSO IS THE ALARM CONTROL TOO!
There you go Neil your all sorted!
VW Golf security/central locking overridden by another fob.
is a cheap alarm. change it wih a proper one.
both of you have alarms which is working on the same freqvency. the same alarm, or just weird coincidence.
2answers
My golf mk4 tdi boot wont open atall
Get hold of a can of Plus Gas or even WD40
Open the slot where the key goes into with a thin screw driver push the thin tube on the can then into the hole
Cover with a piece of tissue , give it a god blast and leave it for a few hours
Do it again and this time gently rock the key as if you are trying to opem the boot
It should free off
As they say if you dont use it you lose it !
10helpful
3answers
Volkswagon Golf Mk4 rear door handle locked!
Theres a video of how to open your mk4 car door with the child lock on, on youtube.
Three Doors Deadlocked on VW Golf 1999 model
actuators working on all four
locking module could be out of sequence after the one door repaired
drop the vw back into the place where the door lock was replaced
get them to explain
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
