Question about One For All URC-4330 Remote Control
I need the codes for One For All Big Easy URC-3300B07, to program Samsung Slim TV
How do I find the right code for One For All Big Easy remote control URC-3300B07 to work with Samsung Slim TV?
Posted by orismuralles on
    Top Expert:
  • One For All Master
  • 76,455 Answers
If you wish to get setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy. Surf the site patiently.
Posted on Mar 23, 2013
5 Related Answers
Anonymous
SOURCE: I need the code for a sanyo tv with one for all big easy remote
0154, 0159 these are the only two I can find. Hope it helps.
Posted on Dec 04, 2007
Anonymous
  • 129 Answers
SOURCE: need tv code list for urc-4605
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC4605
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(For low price replacement remotes visit www.sparky-uk.com)
Posted on Feb 25, 2008
IrishDruid
Swilin Sampson
  • 2712 Answers
SOURCE: have an urc-3220 remote control
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 22, 2008
Anonymous
SOURCE: ONE FOR ALL "Big Easy" urc-4330b03
There are three codes for Orion TVs: 0236, 0463, and 0179.
Posted on Sep 13, 2009
Anonymous
SOURCE: I NEED CODES FOR TV DAYTEK AND HOW TO PROGRAM THIS
we have a 21" daytek hi def tv with no book or control. help?
Posted on Feb 03, 2010
How do I find the right code for One-For.All Big Easy remote control URC-3300B07 to make it work with Samsung Slim TV?
Codes to check with Samsung brand TVs are 0371,0928,0993,0000,0719,0452. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 23, 2013 | One For All Televison & Video
Tip
All For One URC-3220 Code Search
All For One Big Easy Code Search URC-3220
Do you need to search for codes to program your All for One Big Easy URC-3220 Universal Remote Control to control you TV, cable or satellite box, VCR or DVD player?
To program your One For All URC-3220 remote control to operate your TV, the remote has a code search function.
To search for a code for your TV:
  1. On the remote control, press TV once.
  2. Press and hold SET until the LED blinks twice, then release SET.
  3. Enter 9 - 9 - 1.The LED will blink twice.
  4. Aim the remote control at the the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off.
  5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
To search for DVD or cable box codes, substitute the DVD or CBL button for the TV button in the steps above.
I hope that helps.
_________________________________
To download One for All Big Easy URC-3220 Users Manual click here.
on Apr 11, 2010 | Televison & Video
Big easy one for all urc-3300B07
Check these codes. 0928,0183,0372,0916. If you wish to get setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 23, 2013 | One For All URC-4330 Remote Control
NEED CODE FOR A SONY TV FOR A URC-3220 REMOTE
URC-3220 One for All Big Easy 3 Universal Remote
I can help you to program your One For All Big Easy URC-3220 Universal Remote to control your Sony TV.
Please review my Fixya Tip posts for:
  1. Searching for the proper URC-3220 codes, or
  2. Downloading the URC-3220 users manual / owners guide. This contains all the codes for the brands of devices your remote can control.
I hope that helps.
Sep 18, 2009 | One For All URC-3300 Remote Control
Need code for Sam-tv, using urc-3220 uni remote
I can help you to program your One For All Big Easy URC-3220 Universal Remote to control your Samsung TV.
  1. Searching for the proper codes, or
I hope that helps.
Aug 21, 2009 | One For All URC4110 Remote Control
I NEED A CODE FOR MY REMOTE CONTROL
I can help you to program your One For All Big Easy URC-3220 Universal Remote to control your RCA TV.
I hope that helps.
Apr 10, 2009 | One For All URC-3021 Remote Control
I am trying to program a one for all remote urc 3220 to be able to change cha nnels on my panasonic tv/vcr pv-m2058 for dish. right now i can only get channels 44 and 87
I can help you to program your One For All Big Easy URC-3220 Universal Remote to control your Panasonic TV.
I hope that helps.
Mar 17, 2009 | One For All URC4110 Remote Control
Need code for UCR-3220 to run TV SV2000
I can help you to program your One For All Big Easy URC-3220 Universal Remote to control your TV.
I hope that helps.
Feb 16, 2009 | One For All URC4220 Remote Control
URC-3220
I hope that helps.
Sep 13, 2008 | One For All URC4110 Remote Control
Program control with panasonic tv right codes
I hope that helps.
Sep 09, 2008 | One For All URC4110 Remote Control
One For All URC-4330 Remote Control Logo
131 people viewed this question
Top One For All Televison & Video Experts
Nick Charalampakos
Level 1 Expert
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
