Excalibur AL1810EDP Remote Start Alarm 2 Way Dlx Logo
frank harrison Posted on Mar 23, 2013
Excaliber 1850 after replacing batteries 2 way remote won't communicate
Excaliber ght180 cuts out
Rebuild carburetor or find part number for carburetor and go online some carbs. Are cheaper to buy than rebuild.
Sep 13, 2017 • Garden
Remote hand control won't turn system on. Batteries are OK
1) Change by new batteries type alkaline
2) Clean the contacts batteries with special spray contacts cleaner
3) Retight the springs contacts batteries with plier very well for good contacts.
4) Resolder wires contacts batteries.
5) Reset the code again download for free from www. fitness.manualsonline.com or www. remotecodelist.com
Otherwise you must opent the remote and clean any contact from keypads very well, or go to the repair shop
God bless you
The remote control sensor on the TV has stopped working
If new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
Regards.
1helpful
Remote won't work. Tried new batteries, reprogramming, etc. Universal Remote doesn't work either. LG #42PC5DC
To confirmed if the remote control is working fine, aim the remote control sensor(IR emitter) directly to your cellphone camera. While pressing any button key on the remote control, you can see the flash of an infrared emitted by the remote control if it is working fine.
If you've confirmed that the remote control emitted an infrared but still the tv won't communicate with it, this is an indication of faulty IR sensor board of the TV. Check if there's an obstruction from the IR receiver in front. Keep away all of it, clean the plastic window of the IR receiver with soft clean cloth.
If the symptoms still persist, you have to replace the IR sensor board. Check the actual part no. of the board before ordering.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
My remote wont work on my grundig gu15wdt/gu15wdpcx, have tried changing the batteries and it still doesnt work, where can i get a new one?
Lastly, please don't by a remote with confirming it is a remote problem. You have to be sure before thinking of a battery replacement.
Regards.
It doesn't work
is this a remote to TV or what? I am assuming it's a remote to a TV. If it is not for a TV, let me know, although, the solution is similar to any unit that uses remote control.
There are three possible causes for this problem;
1. Batteries may be dead inside the remote.
2. Remote might be defctive.
3. TV remote sensor/infrared might be defective.
Battries; Simply insert new batteries into the remote and try again. If changing batterises doesn't help, problem as to be from the Remote or TV's infrared.
Yours sincerely
Elect_Comp
2helpful
My remote will not work the tv anymore
there are three possible causes for this problem;
Yours sincerely
Elect_Comp.
My control remote doesn't work
Hi, first if remote doesn't work, try new batteries......
1helpful
The remote doesn't work at all
First, if remote doesn't work, try new batteries......
Regards.
Top Buck Vehicle Parts & Accessories Experts
xxxxxx xxx
oneStan
oneStan
Kardoc
Are you a Buck Vehicle Part and Accessory Expert? Answer questions, earn points and help others
