Question about Connex Radio Communications
Connex 3600 how to adjust swr - Connex Radio Communications
1 Related Answer
One Wire
Dean Pitts
  • 126 Answers
SOURCE: connex 3300hp radio
First off, sorry to tell you, but you can not set your swr with your radio's swr cal knob. Trust me, I own a cb shop and know what I am talking about. I have been working on cb radios for years.
You must have an inline swr meter, which can be purchased online or from a truck stop. The ones at truck stops are cheap ones, but will do the trick for the most part.
You connect your antenna 18ft coax to the antenna plug of the swr meter, and a jumper coax (any length) to the transmitter plug of the swr meter and then to the radio.
Close all doors and make sure no one is messing around with the vehicle or antenna. You must be set up as you would normally be transmitting.
Now set your cb radio to channel 40 and your swr meter to fwd. Key up your microphone and at the same time turn the set knob on the swr meter until the needle is at the line that reads set. Unkey your mic and set the the swr meter to ref. Key up again and note what your reading is. Now leave the swr meter in ref and turn the cb to channel 1. Key up and take your reading. If the reading on ch 1 is higher than ch 40 you must raise the stinger on your antenna. If ch 1 is lower than 40, you lower your stinger. You are trying to get lower than a reading of 3 and as close to 1.5 as possible. If you lower your stinger as far into the antenna as it will go and you need it shorter, you cut the bottom of your stinger no more than 1/2" at a time, and recheck your swr reading after each cut.
Once you have gotten the best reading you can, connect your antenna directly back to the radio.
The setting your swrs is to make your antenna as efficient as possible, by trying to get it as close as you can to a 50ohm impedance. THE ONLY PART OF YOUR SYSTEM THAT CAN CHANGE YOUR SWR IS YOUR ANTENNA, not your coax and not your radio.
On the swr meter, the fwd/ref switch stands for forward (power that is being transmitted out) and reflected (power that is reflected back into the radio.
Just for information sake, the swr cal switch on your radio is used to set the meter to reflect the swr that your antenna is set at. The meter on your radio is like a dummy light on your car. ONCE AGAIN, YOU CAN NOT SET YOUR SWR ON YOUR RADIO, only the antenna!!
Posted on Jan 23, 2008
I recently bought a Connex CX366CE. I plan to install a SLMM-1 SUPER MOD AND SWING POWER MODULATION kit. I plan to hook it to a Viper 25,000 watt antenna. Is this going to work? Do I need an antenna tuner...
you should be fine, check your swr's before and after.a swing kit only throws the carrier and adds more modulation. the connex is a good radio to start with,you should be fine, with the mod kit and radio you will never reach 25k on that antenna with this setup. just make sure the antenna is tuned rite for optimum operation(low swr).
Feb 01, 2015 | Connex Radio Communications
Can I tune my antenna using the meter on my radio?
yes,but you want to make sure your antenna is tuneable.If your SWR is to high or to low you want to be able to adjust the antenna to bring the match up or down.Anything under a 1.9:1 is ok but the lower the better
Jul 15, 2014 | Connex 3300 240-Channels Base CB Radio
Swr will not go under 2.5 even with antenna adjusted up and down
if your swr is higher on 1 then on 40 then your antenna is electrically short and you have to lenghten the antenna.If it is higher on 40 then on 1 then it is long and you have to shorten it. If you have to make it longer then you may have to add a quick disconnect or a coiled spring to make it longer. To make it shorter all you have to do is trim a 1/4 in at a time off the antenna whip but you must keep checking the match until it gets down below 1.5 .
Jan 23, 2014 | Connex Radio Communications
1 mile range on cb
Check cables and connectors.
• check antenna SWR,
A good SWR ranges from 1.2 to 1.5.
• check power output.
Jul 27, 2012 | Connex Cx-366ce Night Runner 40ch Cb...
What do you think is wrong with my connex 4300 HP, I turn it on it powers up,but no adio it has static. It seems to have a dead key and swing. Any ideas? Thanks Jim
You will need an SWR meter to check your antenna. FIRST.
I would find help at a local cb shop.. They SHOULDN"T CHARGE to help you SET the swr. only if you need a part or something ..
I don't charge to SET SWR"s .. only if the cust needs a insulating washer or another antenna, or new coax, so-239 etc... I would be glad to help you.. let me know if we can CB Shop Temple, TX
Any shop shouldnt charge you just to see if it works!!
Nov 25, 2011 | Connex CX-4300HP CB Radio
Radio receiving but not transmitting
There is a good chance you could have blown your final transistor. It could also be something is no malfunctioning in your mic. Is it on frequency? Hook it up to a frequency counter and make sure channel 19 reads 27.185. If it is your final transistor it blew for a reason. Most likely it got hot from a high SWR. 1-1:5 is the goal and no higher than 2. If it he SWR is higher then 2 the check your coax cables and adjust your antenna. Good luck.
Feb 08, 2011 | Connex 3300 240-Channels Base CB Radio
I have a connex 33tlm3 works good whith litllie ant squels whith big could something be tuned up to much
Hi jeremy, my name is John. Welcome to FixYa. I think you are saying you are trying two different antenna,s. With the big one, sounds like you have a high SWR. or a bad ground. Make sure that your antenna is grounded good and nothing is blocking it. You will need a SWR meter and a three foot jumper to check this. How to check this is take one end of the coax jumper and run it to the radio and the other end to the meter where it is marked radio. Now take the antenna and put it in the other fitting marked ANT. Set the dial on the meter to SWR SET then turn off all your modulation,MIC GAIN, POWER MIC, now key the MIC and adjust the needle where it says calibrate all the way to the edge of the scale, not going past the edge, with the MIC still keyed up, turn the switch to SWR. that reading you see on the scale is your SWR. If it reads a three (3) or over, it is to high. Depending on your antenna, there are adjustments. Thanks for choosing FixYa...John
Dec 08, 2010 | Connex 3300 240-Channels Base CB Radio
Fresh install SWR will not come down
have you checked the coax connectors? It's gotta be a bad connector,damaged coax or a defective antenna. Careful--don't test "too much" or you'll burnout the final amp!
Dec 27, 2008 | Connex 3300 240-Channels Base CB Radio
Radio Communications Logo
160 people viewed this question
Top Connex Radio Communications Experts
Tony Raia
Marvin
Marvin
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
