KitchenAid KCM511 Coffee Maker Logo
A
Anonymous Posted on Mar 23, 2013
Model: kcm534who ser,no:wtt5131909 heating element for coffee maker kichen aid.
Pictur of heating element kitchen aid coffee maker model:kcm534who.
5 Related Answers
Anonymous
  • 379 Answers
  • Posted on Dec 27, 2008
SOURCE: I dont have a manual
http://www.kitchenaid.com/custserv/service.jsp
best i can do is give you link to kitchenaid support , type in your model number on that page and download the manual , since we don't know your model number , if you need more help please give model number .
Anonymous
  • 145 Answers
  • Posted on Jul 08, 2009
SOURCE: kitchen aid coffee pot says error 2
An ERR 2 may be cleared by a simple reset of the coffee maker. This means unplugging the unit and plugging it back in. When powered back on, select a brew function to see if the error reappears.
If it does, ERR 2 indicates an internal error with the computer of the warming plate. This may be covered under Kitchenaid's 1 Year Hassle Free Warranty. I would advise you to call Kitchenaid Customer Service to see what options are available to you. Repair is not recommended, as it is not cost effective for the company or the consumer.
Their toll-free telephone number is 1-800-541-6390.
Anonymous
  • 145 Answers
SOURCE: Kitchen Aid coffee maker err2
An ERR 2 may be cleared by a simple reset of the coffee maker. This means unplugging the unit and plugging it back in. When powered back on, select a brew function to see if the error reappears. This may take a few seconds.
Anonymous
  • 145 Answers
SOURCE: kitchen aide coffee maker model #KCM534 shows an
Anonymous
  • 145 Answers
  • Posted on Aug 08, 2009
SOURCE: operating manual for kitchen aid coffee machine
Manuals and guides may be located online at KITCHENAID.COM.
In the upper-right hand corner of the site, click on CUSTOMER CARE and then click on LOCATE MANUALS AND GUIDES.
It will then ask you for your model number.
For a coffee maker, the model number is located on a white sticker underneath the machine.
On the website, type in your model number exactly as it appears on this sticker and click GO.
This will then bring up the literature listing for your particular unit. You will need Adobe Acrobat Reader to view the files.
Also, Kitchenaid Customer Service will send you a physical copy of an instruction manual at no charge if you choose to call them. Their toll-free telephone number is:
1.800.541.6390.
Replacement Carafe for KCM300?
Hello, Diana -
I hope I am correct in thinking yours is a Kitchen Aid model of coffee makers.
If you reside in the USA and if you have not already contacted the KitchenAid company, then this is the the web page with KitchenAid contact information:
https://www.kitchenaid.com/service-and-support.html
You can ask about where to purchase a replacement carafe for your model of KitchenAid coffee maker.
Best wishes.
Coffee maker
This model of coffee maker has an adjustable heating element beneath the carafe - ensure the temperature setting for the carafe is high enough to keep the coffee hot.
If the coffee is not brewing hot, the initial heating element/coil may have failed. Removal of the heating element is somewhat problematic and will require disassembly of the water container and base of the coffeemaker, and will likely need to replace the heating coil contained in a plastic sheath. Ensure you take a look at: http://home.howstuffworks.com/coffee-maker2.htm
for further detail.
Kitchen aid proline coffee make not getting any power. have checked outlets.
There are (I think) three possibilities:
1. There is a fuse inside the unit.
2. The water heating element has a thermal fuse that has failed as a result of overheating (no water in the reservoir at some point)
3. The control panel has failed or the low-voltage power supply that powers the control panel has failed.
My guess would be #2. This is a readily available part (electronic supply stores) but not easy to replace (unit disassembly can be quite challenging). If you're handy, give it a try. The thermal fuse will be wired directly across the terminals of the water heating element. It will have very low resistance (~1 ohm) if it is good.
Heating element
there is a number on the heating element, the model of your toaster oven should be on the backside of the unit itself, armed with this info, you should be able to find a replacement element
I push the start button (the one with the red light) and the light turns on, but then nothing happens. (Yes, I had water in the tank and coffee in the filter part.) Usually, I push the button, the light...
Sounds like there an issue with the heating element. When the element goes bad it wont pull any water from the tank nor will it heat the water sending it up through the shower head and onto the beans. Unfortunately, since Braun has discontinued ALL kitchen appliances here in the US many of the parts are obsolete including the heating element for this machine.
79helpful
9answers
Error 2-Unit will not heat or brew. Stopped in middle of brewing cycle and flashed error 3 code. After unplugging unie and plugging back in an error 2 remains.
Error message 2 is a result of the water heating element burning out. The element is replaceable, if you can find a vendor who sells the element assembly. Price of a new element may be more that a new pot though, if you're lucky enough to find a parts vendor that sells one.
2helpful
3answers
Same ERR2 message
the error refers to a faulty motherboard or heating element. There is no fix but Kitchen Aid has been replacing this defective model but if you decide to go for another model fine
We have it in our off kitchen. we plug it into the
There might be a crack in the element, or the machine might draw more than 20 amps when heating. Check the label for the wattage, multiply that by the voltage and multiply the result by 1.25, that should give you the amperage needed.
TIME AND TIMER PROBLEMs
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KCM511&siteCd=KAD
If not that model, you should be able to navigate to your particular model. =>
Good Luck!
Top KitchenAid Coffee Makers & Espresso Machines Experts
ZJ Limited
ZJ Limited
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
