Question about Samsung RS261MDBP Side by Side Refrigerator Ice and Water Dispenser -
Our refrigerator is making the bell sound when the door are close
Posted by My'Iesha Muhammad on
NANDINI DUTTA MOU
    Master:
  • 551 Answers
If it has belling system ,it bell alert when the door closed or otherwise you read the catalogue there must be written of this problem solution.
Posted on Mar 24, 2013
Samsung wheezing/ Gasping sound.
It is likely just refrigerant coursing through the coils, or maybe the water valve when it opens to fill the ice maker... Is it constant, or does it come and go at intervals?
May 27, 2016 | Samsung RF4287HABP 28 cu. ft. 4-door...
Refrigerator problems 2-door freezer door stuck will not open
Good Afternoon friend, I appreciate your post!
Based off what you have described the door on your Frigidaire refrigerator is stuck and will not open. It sounds like you may have condensation on your gasket and it has frozen the door shut. The best thing to do is disconnect power from the refrigerator for four to six hours and that should break up any ice holding the door closed. I hope this is helpful information. -Matt
Mar 01, 2015 | Frigidaire FFHT1715L 16.5 cu. ft....
When I open the refrigerator the freezer pops open
I appreciate your inquiry, Tammy McAninch!
Based off the information you have provided your Frigidaire freezer door pops open when you open your refrigerator door. This can happen with new refrigerators because the seal is new. I understand your question is labeled under model FGHB2866PF. It could be issues with your door not aligned properly and hitting your freezer door to open. I would check the gasket to make sure they are creating the proper seal on your freezer in order to check that you can use a dollar bill. Place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If nothing is stopping the door from closing then replace the gasket. If you continue to experience issues with your freezer door I would recommend reaching out to a professional for further assistance. I hope this information helps to some degree. -Matt
Nov 17, 2014 | Frigidaire Gallery Series FGHB2866PF 27.8...
My Samsung Refrigerator is making a noise that sounds like an old style door bell. It a loud buzz that occurs several times a day. Do you have any ideas?
User manual and parts list and diagrams.
SAMSUNG Refrigerator Parts Model RF217ACPN XAA
Your refrigerator has at least three motors with fans in addition to the compressor motor. The one most suspect is the one that passes air from the freezer to the refrigerator.
samsung refrigerator noise YouTube
Oct 19, 2014 | Samsung RF217ACPN - 20 cu. ft. French Door...
Why is my upright igloo freezer not staying close
The door sometimes warps and need to be lightly twisted back to where all four corners make contact and seal.
Your unit may need to be tilt back a bit so the door wants to close y itself, the front foot pegs are adjustable and can be turned to make the front higher or lower than the back side of the cooler, gravity closes the door when the unit is leaning back.
Aug 28, 2014 | Igloo Cooler Igloo 4.6 cu. ft....
My kenmore is not pressure sealing
the problem is that the compressor is not working
call a technician for a proper diagnosis
and it is not a pressure sound but a vacuum sound as the door when closed drops the temp inside the unit and that creates a vacuum making the door temporarily hard to open
May 15, 2017 | Kenmore Elite Side By Side Refrigerator -...
My Miele freezer the alarm bell is bleeping but it is not defrosting what could be the problem please.
The beeping could be a low temperature warning. Check to make sure the temperature is staying cold enough and then check the door seal. Use a store bot fridge/freezer thermometer. Use a dollar bill to check seal. If you close door on the bill it should hold the bill tight but still let you pull it out. If it is loose then you need to adjust the door to fit tighter.
Sep 21, 2010 | Miele Freezers
Sub zero refrigerator model 532 problem the freeze is warm on the top but the ice & items below the ice are OK. i suspect that the light may be always on. also the freezer door does not make its...
I suspect a bad fan motor, door switch, or not defrosting.The suction when door closes is caused by the low temperature created when working properly.
Feb 14, 2010 | Freezers
Samsung RS261MDBP Side by Side Refrigerator Ice and Water Dispenser - Logo
138 people viewed this question
Top Samsung Freezers Experts
Tad
Level 1 Expert
Harrie
Are you a Samsung Freezer Expert? Answer questions, earn points and help others
