Fellowes Microshred MS-450Cs Logo
william Posted on Mar 23, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Shredder blades not turning - Fellowes Microshred MS-450Cs
Anonymous
Level 3:
  • Master 32,281 Answers
  • Posted on Mar 23, 2013
Anonymous
Master
Level 3:
Answers
32281
Questions
Helped
7913137
Points
102259
A staple or paper clip has jammed the cutter blades.
If there is a reverse switch then reverse to free the cutter blades and remove these objects.
Clogged shredder blades
Please don't put your fingers near the shredder blades or put any foreign object near the shredder blades when operating the machine.
Most machines will allow you to reverse the shredder blades and it will clear the clog.
If this doesn't work, I turn the machine off and unplug it. Then I use tweezers to pull the paper out.
Good luck.
Paul
Our C220c shredder does not shred, motor turns and blades turn but i think the blades are blunt. Can you get new ones or have the old blades sharpened?
There are 2 shafts that have the cutting blades on them and they both should turn. I have replaced many gears on this model and suspect that a gear is broken. Fellowes does not have many parts this model anymore. I would call a local shredder repair service or you can call Fellowes at 800-955-0959.
Shredder will not turn off
Unplug the shredder from the power outlet. Remove the paper canister. You will need a can of air to blow all areas both from inside of the shredder around the blade area and outside of the shredder around the blade area. After you complete that part, Check the sensor area to make sure no paper is jammed around it. Plug the shredder back in and turn it on. If that fixes the problem, get a sheet of paper and put some shredder oil on it and put it thru the shredder for lubrication.
2helpful
My shredder squeaks when in use, does it need regular lubrication? If so, what do I use?
Visit the link below for various types of shredder oils.
http://www.factory-express.com/Shredder_Oil__Bags-2025.htm
Regular use of paper shredders creates paper dust that can dry out components, dull the blades, clog the machine and burn out the motor. However, with proper oiling and maintenance, a paper shredder can last for years.
Oiling a shredder can be accomplished using one of two quick methods. The paper method limits excess oil to the paper, reducing the chance of it splattering when you turn the machine back on. This method is more common than the second and can be used with all kinds of shredders. The paperless method may be less common, but it is just as effective at removing dust buildup from the blades of the shredder.
The Paper Method:1. Place a sheet of paper on or above a surface that will not be marred or damaged should you spill oil on it.2. Apply the oil to one side of the paper in a wide zigzag pattern across the whole face of the page to ensure sufficient coverage. Do not saturate the paper with oil.
3. Turn the shredder on and run the oiled piece of paper through the shredder. As the paper shreds, the oil that has been absorbed by the paper will lubricate the blades. The motion of the blades will distribute oil so the shredder continues to operate smoothly.
3. Feed a few more papers into the shredder to absorb residual oil from the cutting assembly. The Paperless Method:1. Set the shredder to manual mode so you can control the direction of the blades and the amount of time the blades are in motion.2. With the paper shredder turned off, squirt a solid line of oil into the paper entry lengthwise across the paper-shredder blades.
3. Start
the paper shredder in reverse, allowing it to run for 10 to 20 seconds before stopping the blades. This will evenly distribute the oil to all parts of the cutting assembly.
4. Return
the shredder to automatic mode. Then feed two or three sheets of paper into it to absorb the excess oil from the machine. Tip:
How often you should oil your paper shredder depends mostly on how much you use it. Office shredders that see heavy use every day will need to be oiled several times a week, while home machines used occasionally need be oiled only a few times a year. Cross-cut shredders will require more frequent oiling than other paper shredder varieties because they have more blades and create much more paper dust.
You can purchase a shredder lubricating oil from any major electronic or office supplies store or you can contact Royal customer service at 908-429-4357.
1helpful
How to lubricate a Black & Decker Model BD-s600 paper shredder
    • 1 Turn the paper shredder off and unplug it.
    • 2 Clean out the paper shredder. Make sure the blades are free of paper bits and debris. Remove pieces of paper that are jammed around the blades.
    • 3 Spray the shredder oil through the blade opening or throat of the shredder. Spray it in a stream.
    • 4 Plug the shredder back in and switch the reverse button on. Then run it for 10 to 30 seconds in reverse to allow the blades to be saturated with shredder oil.
    • 5 Put the shredder in forward motion and let it run again to disperse the oil thoroughly to all areas of the cutting blades.
    • 6 Feed a couple pieces of paper through the blades to be shredded and absorb any extra shredding oil.
Read more: How to Lubricate Paper Shredders ' eHow.com http://www.ehow.com/how_5761042_lubricate-paper-shredders.html#ixzz1kDQGrxZ8
Shredder does not work
Hello there. I'm sorry to hear about your shredder I'm sure there is something we can do. The first thing we need to do is check to see that it even turns on. If there is a light that turns on while plugged in then we know that it is properly turning on. If the light is off then it must be an electrical problem, either with your socket or your shredder. I recommend trying a different socket.
BEFORE TRYING THIS STEP, MAKE SURE TO TURN OFF THE SHREDDER!
If it turns on correctly you might want to see that the blades aren't stuck with paper. TURN OFF the shredder and try and move the blades with a screwdriver or a flat head. You can also see the paper in some printers. If you cannot see the blades then we can take an alternative.
You can find shredder oil in any office supply retail store. You put some oil on the blades and it lubricates them, and at the same time eats away the paper that is stuck. Most times this is the problem. If you can't go to the store you can use a little bit of cooking oil. That will do the trick as well.
If none of these methods work than it must be an electrical problem in the shredder. Hopefully not however.
Good luck
- Oblivior72
Ran something with stickers through my shredder, now it won't run
Check and see if the cutting blades are turning when the shredder is running...if the cutting blades are not turning then you probably have stripped a gear inside...you will have to open it to check.
1helpful
I own a Royal RL170MX shredder. I turn on the
If the blades rotate then the paper should go in...just be sure the blades are turning in the forward direction and not in reverse.Also make sure you lubricate the blades with shredder oil.
1helpful
Staples(Fellowes?) micro cut shredder - blades not turning
Sometimes the main gear is attached to the motor with an ALLEN SET SCREW
2answers
XF50D motor won't turn shredder blades
There is no viable solution.  There are no replacement parts available.  The Office Depot shredder is a cheap low quality product made by a cheap company.  The FIXYA service agreement costs more than the product.  Bad choice to buy the product!
Top Fellowes Office Equipment & Supplies Experts
midnightmove
Level 1 Expert
Sean Wright
Sean Wright
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
