Any misfiring while its running? Codes? I did have a dodge once that did this and sometimes wouldnt start back up for an hour or so. After throwing lots of $$$ at it turns out map sensor. Good luck.
Start by pulling the paper tray out. This will cause the printer to finish the page it was on when it was interrupted rather than paper jam somewhere in the machine.
Once you have interrupted the print job this way then you can cancel the print job from the PC and then once that has been done turn the Printer off for a few minutes to clear the memory buffer.
The temperature gauge on ALL car should always start at the extreme cold end, because of the accuracy range of the sensing device.
Your sputtering and stalling might be a automatic choke problem.
Knowing this will happen you can brake with your left foot and press the accelerator just enough to prevent the stall, when you have to stop.
Get a can of carburetor cleaner, take the filter / intake cowling off, and spray all moving parts of the carb really well.
turn off ur printer disconnect it frm computer and check ur computer where there is pending printin left by you,if yes cancel all the pending printing and connect ur printer back to computer and turn it ON,u shall not face the problem.
Let the printer run out of paper. Then left click START, left click SETTINGS, left click PRINTERS AND FAXES. Right click on your printers icon to view the drop-down menu. Left click on OPEN to view the print queue. If any jobs are displayed, clear them by left clicking on PRINTER tab in the queue display. From the printer drop down menu, left click CANCEL ALL JOBS. This should solve the problem. If not, shut down , turn off, and unplug your computer and all periferral devices from the wall. and unplug the printer from the computer, Wait at least 30 seconds and reconnect all devices. Turn all devices back on and check operation.
