Question about Citizen Eco-Drive Calibre 8700 Wrist Watch
Citizen eco drive man gold #4n0403 k001536ku watch manual
I need the manual of this man gold watch citizen eco drive
Posted by mario huertas coccio on
  • Citizen Master
  • 18,429 Answers
Click this link then follow instructions to get manual
http://www.citizenwatch.com/en-uk/support/setting-instructions/
Posted on Mar 23, 2013
5 Related Answers
Anonymous
  • 73 Answers
SOURCE: Setting the time on a Citizen Eco-Drive Watch
Go to this link and pay particular instructions on how to find your watches movement or caliber number.
http://www.citizenwatch.com/COA/English/settings.asp
Posted on Dec 31, 2007
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: CITIZEN BL9000-59F MEN ECO DRIVE WATCH minute repeater
Try this link:
http://www.citizenwatch.com/CUK/English/settings.asp
Everything you need for the caliber number and settings is here.
Do not forget to rate, please.
Posted on Feb 24, 2009
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: Need manual for Citizen Eco-Drive Calibre 8700.
Use this link: http://www.citizenwatch.com/COA/English/settings.asp Fill in requested details of your watch and click on GET SETTING INSTRUCTIONS, then click on INTERACTIVE SETTING INSTRUCTIONS. There you will find everything you need to set up your watch. You can download instructions on this site as well.
Rate me, please.
Posted on Jan 08, 2010
Testimonial: "Provided great info and quickly."
Anonymous
  • 8 Answers
SOURCE: i need user manual citizen eco drive calibre 8700
http://g-ecx.images-amazon.com/images/G/01/watches/H500_ebook.pdf
this should take care of your needs!
Posted on Mar 21, 2010
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: need to shorten my band
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Posted on Jul 31, 2010
How o set my watch to the correct time date and day please my watch is a citizen eco drive wr 10 bar
Setting Instructions - Citizen Watch - English (CA)
www.citizenwatch.com/en-ca/support/setting-instructions/
  1. Cached
  2. Similar
Need additional assistance? Our support team may be reached at: 1-800-461-4189 8:30AM - 5:00PM EST, Monday - Friday [email protected]citizenwatch.
[PDF]instruction manual - CITIZEN WATCH Global Network
www.citizenwatch-global.com/support/pdf/8720/e.pdf
  1. Similar
Visit the Citizen web site (http://www.citizenwatch-global.com/) to view visual guides for ..... Eco-Drive watch handling precautions ... Water resistant to 10 or 20. citizen eco drive wr 10 manual - Google Search
Apr 06, 2017 | Citizen Watches
Gold wristband, need to take a link or two out of it. do I need to go to the jeweler ECO-Drive
I would suggest taking to the jeweler you bought it from. But here is a link to Citizen that will help you in your search for instructions to do it yourself:
http://www.citizenwatch.com/COA/English/faqs.asp?topic=Bracelet Sizing
Best regards
Aug 23, 2010 | Citizen Eco-Drive BL5184-56L Wrist Watch
I would loke a operating or instrution manual for citizen eco dri
mcdevito75 here, BEST BET contact Citizen at www,citizenwatchserv.com use the contact likk on that website.
Jul 11, 2010 | Citizen Eco-Drive Calibre 8700 Wrist Watch
Had battery replaced
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CITIZEN watch manuals. Rate me, please .
Apr 08, 2010 | Citizen Eco-Drive Calibre 8700 Wrist Watch
Citizen Eco-Drive
Could be that the watch inside and outside numbers do not match. If the dial says Eco Drive, that should be the first step. Next, find out about the 4 digit number that tells you which type we are looking at. You may want to open the back and look at the number on the watch internals. But be aware you may damage the water proof seal in doing so.
Really, you should write down all numbers you can see and send an email to citizen. They will help you.
If you need to know more about the Eco Drive, look for detail tech manuals for all types here: http://www.citizenwatch.com/downloads/tech/tech.htm
Those are great watches as long as you remember it needs light to charge.
Jun 09, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
Dead battery
leave under a desk lamp for 24 hours or similar type of strong light
Apr 25, 2009 | Citizen Eco-Drive 180 Gold Tone Diamond...
Need manual for manual+Citizen Eco-Drive Women's Riva Chronograph Watch #FB1024-51d so I can set the time on it
Go to this site and download manual:
http://www.citizenwatch.com/COA/English/find.asp
Jan 19, 2009 | Citizen Eco Drive Riva Watch for Women
Citizen Eco-Drive Calibre 8700 Wrist Watch Logo
225 people viewed this question
Top Citizen Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Are you a Citizen Watch Expert? Answer questions, earn points and help others
