Maxi-Cosi CabrioFix (Black Reflection) Infant Car Seat Logo
Question about Maxi-Cosi CabrioFix (Black Reflection) Infant Car Seat
Maxi cosi cabriofix harness straps - Maxi-Cosi CabrioFix (Black Reflection) Infant Car Seat
Posted by deirdre Husey on
5 Related Answers
Anonymous
SOURCE: maxi cosi cabriofix infant car seat
If you follow the link at the bottom it will take you to the cabriofix insruction manual on the maxi cosi website. (Their uk website can be found at www.maxi-cosi.com/maxicosi/default.aspx)
Link...
http://www.maxi-cosi.com/media/producthandleidingen/maxicosi/CabrioFix.pdf
Good luck,
T
Posted on Jan 23, 2008
Anonymous
SOURCE: maxi cosi car seat cabriofix
What seems to be a sewn-up loop, is actually easy to unattach, but the trick is not explained in the manual.
Where the end of the strap seems to be holding to the seat's plastic shell, the plastic is not completely connected, there is a break in the plastic. Just move the strap left/right a bit and you will see that you can unattach it there. Then you can unthread the loose end of the strap and completely remove the cover.
Credits for this go to my wife who figured it out after I already thought we should return the seat to the shop. :p
Posted on Jun 07, 2008
Anonymous
  • 419 Answers
SOURCE: i've removed the maxi cosi cabriofix cover to wash
Yes you can, this is called a Quick Adjuster I think and costs very little.
Contact www.maxi-cosi.com who will advise you.
I hope this helps.
Posted on Sep 15, 2009
Anonymous
  • 419 Answers
SOURCE: I need a replacement maxi cosi cabriofix crotch
If you contact www.maxi-cosi.com you will be able to order this part.
I hope this helps.
Posted on Nov 29, 2009
Anonymous
SOURCE: Is Maxi-Cosi Mico Base compatible with CabrioFix?
No, they are not interchangeable.
Posted on Jan 05, 2010
I took the maxi-cosi straps of to wash and now do not know how to put them back.
Due to the safety implications of the harness being incorrectly fitted the harness should never be removed. To get the harness back in the carseat safely the carseat would need to come to the engineers for them to carry out this work. Please call the customer service department on 01284 413 141 Mon-Fri 8.30-4.30 to discuss.
Can I get replacement straps for the maxi cosi cabriofix?
Your Maxi Cosi CabrioFix can be fitted with new straps.
Since this is directly affecting the safety of the seat the procedure is only available from a Maxi Cosi service center.Please visit a Maxi Cosi dealer to have your seat sent to a service center.
I hope this helps.
Erwin de Raadwww.babycare.nl
I recently removed the cover of my maxi cosi priori car seat to wash it. Now I cannot work out how to put it back on. Basically I have unhooked both shoulder straps that I think were previously threaded...
Good Afternoon
Go to www.maxi-cosi.com and select the CabrioFix carseat to download a replacement instruction manual for details of how to replace the fabric.
The harness should not have been completely removed from the carseat in order to remove the fabric. If the harness has been completely removed we cannot advise that you re-thread it due to the safety implications of it being incorrectly done. In this instance please contact the customer service department on 01284 413 141 Mon-Fri 8.30-4.30 to discuss the carseat being sent to our engineers for them to re-thread the harness.
Cannot refit maxi cosi car seat straps after washing
Hello - The harness straps of any carseat should not be removed as the re-threading of them requires specialist tools. Due to the safety implications of the harness being incorrectly re-fitted, the carseat would need to be sent to the engineers for inspection and repair as required. If you're in the UK please contact the customer services department on 01284 413 141 Mon-Fri 8.30-4.30 to discuss.
Where can I order a two spare shoulder pad for the straps to my maxi cosi black car seat?
Good Afternoon
If you are a UK customer, replacement harness pads for the Maxi Cosi CabrioFix can be ordered via your local authorised retailer or direct with the customer service department on 01284 413 141 Mon-Fri 8.30-4.30. The harness pads are available in plain Black only, as a set of three, and are RRP £15 (with £3.99 p+p if ordered direct).
If you're in another country, go to www.maxi-cosi.com and select the country you're in, then use the "Contact Us" tab to ask if they're available in your country to order.
Once removed how do you replace the cover and put the strap back correctly for rear facing maxi-cosi car seat?
Good Evening
Instructions for replacing your fabrics are in your Maxi Cosi CabrioFix user manual. If you no longer have your user manual you can download another copy at www.maxi-cosi.com and selecting the CabrioFix carseat. Above the product image you will see a tab to download a user manual.
If you have removed the harness from the carseat completely this carseat needs to be sent to our engineers for them to re-thread the harness. Due to the safety implications of this being done incorrectly we cannot recommend that this is done by anyone else. The standard charge is £50 and this would include courier delivery service of the carseat back to your address. In addition you will need to make arrangements and cover costs for a courier delivery service of the carseat into our engineers.
1helpful
Lost my straps for maxi cosi cabrio carseat, can i buy new ones and install myself?
hi yes you can do it yourself easy to do if you in the uk
http://cgi.ebay.co.uk/Maxi-Cosi-Cabriofix-Car-Seat-Group-0-Harness-/120640170048?pt=UK_Baby_BabyCarSeatAccessories_SM&hash=item1c16b6e840
or contact maxi cosi direct this is for the uk
http://www.maxi-cosi.com/gb-en/contact
if you need for another country please let me know
I've removed the maxi cosi cabriofix cover to wash it and misplaced the round grey button that adjusts the shoulder straps can i replace this
I hope this helps.
Maxi cosi cabriofix infant car seat
Link...
Good luck,
T
1helpful
2answers
Maxi cosi car seat cabriofix
Top Maxi-Cosi Baby Gear Experts
Marvin
Marvin
ray gallant
ADMIN Andrew
ADMIN Andrew
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
