Maxi-Cosi CabrioFix (Black Reflection) Infant Car Seat Logo
Question about Maxi-Cosi CabrioFix (Black Reflection) Infant Car Seat
How to remove maxi cosi cabrio harness straps
The straps have mould so i want to be able to remove harness strap to clean them
Posted by deirdre Husey on
Dorel UK
  • Maxi-Cosi Master
  • 1,637 Answers
Hi
The harness of a carseat should never be removed or replaced by anyone other than a trained engineer due to the safety implications of it being incorrectly replaced.
The carseat fabric should be removed from this carseat and they can be washed - the harness itself should be cleaned in place in the carseat using a solution of stain remover and water and a small scrubbing brush or hard scourering pad to clean the harness. Excess water in the carseat should be dried immediately and thoroughly to prevent any parts rusting. Loose crumbs can be removed using a vacuum cleaner.
Alternatively the carseat can be sent in for the engineers to replace with a new one. Inspection and single repair (replacement of the harness) plus safety checks and courier collection and repair can be booked for 39.99GBP if you're in the UK by calling 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays)
Posted on Mar 23, 2013
5 Related Answers
Dorel UK
Dorel UK
  • 1637 Answers
SOURCE: once removed how do you
Good Evening
Instructions for replacing your fabrics are in your Maxi Cosi CabrioFix user manual. If you no longer have your user manual you can download another copy at www.maxi-cosi.com and selecting the CabrioFix carseat. Above the product image you will see a tab to download a user manual.
If you have removed the harness from the carseat completely this carseat needs to be sent to our engineers for them to re-thread the harness. Due to the safety implications of this being done incorrectly we cannot recommend that this is done by anyone else. The standard charge is £50 and this would include courier delivery service of the carseat back to your address. In addition you will need to make arrangements and cover costs for a courier delivery service of the carseat into our engineers.
Posted on Jan 20, 2011
Anonymous
SOURCE: Maxi cosi Priori, Adjustment of straps to the upper of the three
There is a door in the back of the seat (only accessible when the seat is fully reclined).  You have to open this door.  You can then pull the splitter plate out from behind the seat.  It is easiest to do this if you loosen the straps all of the way.  Remove the straps from the splitter plate, and rethread them through the desired slots and re-attach to splitter plate.  Close the door and you are done.
Posted on Mar 24, 2009
Anonymous
  • 21 Answers
SOURCE: I need fitting instructions for straps for Maxi
You can download the manual on the bottom of this page, just below the award signs:
http://www.babycare.nl/maxi-cosi-priori-sps-bjrn-p-107.html
Hope this helps,
Babycare.nl
Erwin de Raad
Posted on Jun 24, 2009
Anonymous
  • 419 Answers
SOURCE: i've removed the maxi cosi cabriofix cover to wash
Yes you can, this is called a Quick Adjuster I think and costs very little.
Contact www.maxi-cosi.com who will advise you.
I hope this helps.
Posted on Sep 15, 2009
Anonymous
  • 419 Answers
SOURCE: Lost shoulder strap
If you contact this link, you will be able to purchase parts for your carseat:
http://www.maxi-cosi.com/maxicosi/forms/contact.aspx?mode=contact&language=gb-en
I hope this helps.
Posted on Nov 15, 2009
1helpful
How to remove maxi cosi priorfix harness straps
Hi Deirdre
Due to the safety implications of the harness in your carseat being incorrectly fitted we must recommend that you do not attempt to remove or replace the harness yourself.
Should you wish to have it replaced you can send the seat to our engineers for inspection and replacement of the harness plus safety checks to confirm that it is working as per specification. 5bac1756-b7e9-4806-aa74-da8d8a038fa4.jpg
Ive pushed button and straps on my maxi cosy cabrio car seat will not loosen, help??
Hi
When you press the silver / grey button at the front of the carseat you should pull both harness straps at the same time and it should loosen the harness. If this is not happening the carseat needs to be inspected. Please contact your retailer with proof of purchase if it is under 12 months old. Alternatively please let us know what country you're in and we can put you in touch with the correct customer care team to assist.
Can I get replacement straps for the maxi cosi cabriofix?
Your Maxi Cosi CabrioFix can be fitted with new straps.
Since this is directly affecting the safety of the seat the procedure is only available from a Maxi Cosi service center.Please visit a Maxi Cosi dealer to have your seat sent to a service center.
I hope this helps.
Erwin de Raadwww.babycare.nl
Cannot refit maxi cosi car seat straps after washing
Hello - The harness straps of any carseat should not be removed as the re-threading of them requires specialist tools. Due to the safety implications of the harness being incorrectly re-fitted, the carseat would need to be sent to the engineers for inspection and repair as required. If you're in the UK please contact the customer services department on 01284 413 141 Mon-Fri 8.30-4.30 to discuss.
Hi, i cannot get my maxi cosi to recline. can you offer any help with ideas?
Hi Lorna - Most commonly this issue is caused by dirt/debris getting caught in the tensioning strap of the harness and gradually pulled into the mechanism of the carseat over time. First recommendation is to remove carseat from the car and remove cover (do not remove harness system from seat) give the carseat fabric and the seat itself a clean and see whether this improves the recline situation. If not, please contact your customer services department - if you're in the UK this is 01284 413 141 Mon-Fri 8.30-4.30
Hi i have got a maxi cosi cabriofix car baby car seat and cannot seem to remove the cover at the bottom where the grey circle is how do i do this and can i was the cover in the washing machine once...
Good Morning
The grey tensioner strap appears to be stitched in place but it isn't. Follow it around under the bottom of the carseat and the strap is in a piece of plastic catch shaped like an H on it's side. Wiggle one way then the other to unhook from this catch, and the carseat fabric can be removed (where the grey circle part is the fabric is tucked underneath slightly, once you've unhooked the tensioner strap you'll be able to get the fabric off easily).
Hand washing is recommended, but if you have delicate or handwash cycle on machine this is also suitable. Use a mild detergent and maximum temp 30 degrees for washing. Do not tumble dry: Do not leave in direct sunlight to dry. Ensure fabric is completely dry before putting it back on for use as damp fabrics may result in mould or mildew growth.
Remember never remove the harness straps from the carseat, the fabrics can be completely removed while the harness remains in place!
Hi can i remove all the harness straps from my maxi cosi priori xp to wash or replace them?
Please do not wash your harness straps, they should not be submerged in water only spot cleaned.
If you have already washed them or just want to purchase replacement straps they are available on the last page of your manual.
I found an online copy of the manual here as well in case you have misplaced yours:
http://tiptoeturtle.com/assets/product_files/instructions/Maxi-Cosi/MaxiCosi_Priori_manual.pdf
1helpful
I need replacement straps for the maxi cosi cabrio carseat. Where can I get these.
hi I think your best option is to contact maxi cosi details here Customer Care Advisors Telephone: 01284 413141I have tried other options and i can not find any to buy
1helpful
Lost my straps for maxi cosi cabrio carseat, can i buy new ones and install myself?
hi yes you can do it yourself easy to do if you in the uk
http://cgi.ebay.co.uk/Maxi-Cosi-Cabriofix-Car-Seat-Group-0-Harness-/120640170048?pt=UK_Baby_BabyCarSeatAccessories_SM&hash=item1c16b6e840
or contact maxi cosi direct this is for the uk
http://www.maxi-cosi.com/gb-en/contact
if you need for another country please let me know
Hello can you buy spare pads for shoulder straps for a maxi cosi cabrio fix car stat
look on ebay or any black or red ones will be fine my sister used her pads with my car seat
Top Maxi-Cosi Baby Gear Experts
Marvin
Marvin
ray gallant
ADMIN Andrew
ADMIN Andrew
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
