Recently bought a Benq GL2250 Led Monitor only to find that after a week or so's use a i have a column in my screen about 3 inches wide in which the pixels are of a much lighter color. Is this a monitor problem as it only seems to affect the darker colors in the screen?
SOURCE: I have a Philips 17 inch flat screen lcd monitor.
I believe this is the end of your monitor. Maybe it bit the dust by the time you read this.
SOURCE: 3 pixel wide stripe on lcd
Hi Casey,
If the problem is getting worse, than either the pixels are dying (so to speak) or you might have a problem with the monitor's screen.
Unfortunately, if either of the above are true, then the only way to fix it would be to replace the screen, which can be quite expensive. If you agree that this is the problem then you'd be better off getting a new monitor instead of spending money to get it repaired.
Good Luck.
