Question about Lazy Boy La-Z-Boy Power Lift Recliner Cashmere
Recliner foot rest bolt broke and spring came off
Bolt broke and spring came off
Posted by jackie on
frank
    New Friend:
Looking for two small springs that go in the foot lift section of a lazy boy recliner. these springs allow you to raise the foot lift to different positions. these are very small springs and attach to each side of two small drum types.
Posted on Jun 29, 2013
The button broke on the parking brake & the spring came out. Brake still works if you put spring in and pull up brake and hold spring down.
You'll have to replace the whole assembly. You'll have to remove the console to get it out. It will screws/bolts in the rear, in the box, under cup holder pads, on the sides, and up front. depends on your vehicle where the bolts are. This is every where I have found them.
May 29, 2016 | Cars & Trucks
Re cliner foot rest wont open need digram to fix
How to Fix a Reclining Lounge Chair - DIY Recliner Repair ...
? 2:28
https://www.youtube.com/watch?v=0P4cHbjiJmc
May 29, 2012 - Uploaded by How to... Science, Craft Plus Other DIY Fixes
Is your footstool not working / not rising up? ... How to Fix aReclining Lounge Chair - DIY Recliner Repair - Fix a Broken Plastic Foot Stool Lever ... Hi there any ideas on how to fix the back of the recliner its stuck in open position? I have removed it and the steal bars that the back attaches to wont align ...
Recliner Mechanism - YouTube
Dec 19, 2015 | Health & Beauty
Fix the foot rest
Please state what part isn't working, does it open or won't it close or is it crooked? Send a picture if possible
Mar 02, 2015 | Furniture
How to fix at reclining mecanism
Should only be 4 bolts holding it in ?, If You have the tools toremove lube up the frame , but be very careful about the recliner , usually a heavy duty Tension spring could get dangerous if you mess with it ! any Uposery shop should be able to fix it
Jun 06, 2014 | 2010 Chevrolet Chevrolet Malibu LT
Lazyboy recliner foot rest will not stay up!
Check the spring that holds the foot rest closed or open. Flip the chair over and take a look.
Mar 30, 2014 | Furniture
Lafer spring
I have Lafer Kiri chair and spring for foot rest broke
i found replacement spring at Lowes
It is Hillman replacement spring 2 per pkg
Bar code 08236 80104
Works great
Nov 30, 2013 | Lafer Kiri Recliner Chair Cherry Red,...
Simmons rocker recliner footrest spring placement
my spring on my footrest on my simmons recliner broke,when I replace it, where does it connect on the chair ?
Oct 24, 2013 | Simmons Rocker Recliner
Foot rest on recliner will not stay locked in position
your footrest spring has stretched out not providing proper tension to hold footrest in place
Oct 22, 2013 | Lane Furniture Lane Stallion Comfort King...
What exactly is a recliner? How is it different from other chairs?
A recliner is a type of chair that can tilt backward. They usually come with a built in foot rest that comes forward when the user tilts back. They have the ability to adjust from a slight incline to lying almost flat.
Aug 09, 2012 | Furniture
Lazy Boy La-Z-Boy Power Lift Recliner Cashmere Logo
2,484 people viewed this question
Top Lazy Boy Furniture Experts
John Tripp
John Tripp
Tom Chichester
Are you a Lazy Boy Furniture Expert? Answer questions, earn points and help others
