Question about GE G.e Refrigerator Wr55x10942 Motherboard Main Board
GE model Pfs22miwww. Condenser fan and compressor not running. Tested start cal it is ok. Changed ontology board. Condenser fan now running. Still no compressor
Posted by Bill Dick on
John Tripp
  • GE Master
  • 4,656 Answers
Have you changed out the WR55X10942 Motherboard? Here is a link to test points on the motherboard HERE and here is a service manual HERE I don't mind helping answer your questions so feel free to contact me, Thanks Sea Breeze
WR55X10942 Main Control Board
GE model Pfs22miwww. Condenser fan and compressor  - 3_22_2013_10_08_23_pm.jpg
Posted on Mar 22, 2013
5 Related Answers
Anonymous
  • 19 Answers
SOURCE: Evaporator fan not working
Ha ha
Most G.E. the fan will not work if limit control is not working, staying in open position.This also means the defrost heater will not work. If you had an amp probe it would simplify your diagnoses. you could put it into defrost,and if the amps showed heater was not coming on it would prove my theory. The limit control is a small button like switch about 1 inch in diameter cliped to the cooling
coils in back of freezer. Hope this helps.
Fxit
Posted on Feb 21, 2008
Anonymous
  • 68 Answers
SOURCE: Ice Maker doesn't work, condenser fan was not running
Hi Cecil
Im Dave
Hopefully I can help. If your fan runs then all freezer is getting cold than the fan is not your problem.
MODULAR CONTROLS
An icemaker's motor and switches may be in a module that must be replaced as a unit if any one part is bad. Holes in the module let you test the parts. CAUTION: Unplug the refrigerator before testing the icemaker motor or heater. Don't touch the jumper wire when testing the thermostat.
To use the test holes in the module, take off the icemaker cover and insert VOM(volt-ohm meter) probes in the holes. The components to test are usually listed inside the cover. When testing, shutoff arm should be down, and ejector blades should be in normal resting(2 o'clock) position.
To test module motor with VOM on RX1, insert probes into test holes L(line voltage) and M(motor). Look for a reading indicating significant continuity. Test heater in holes L and H(moldheater); look for a reading near 72 ohms. To replace module, take out screws and pull off. Replace entire module. If heater tests faulty, unmount icemaker, unscrew housing from ice mold-heater unit, and replace mold-heater unit.
Test thermostat with freezer cold. Unplug refrigerator. Insert bare ends of an insulated wire in holes T(thermostat) and H. WITHOUT TOUCHING WIRE, plug in refrigerator. If motor runs, replace thermostat. To replace thermostat, unplug refrigerator and unmount module and housing. Slip thermostat out of housing. Replace thermostat, using special metallic putty where it touches mold.
SEPARATE CONTROLS
In a non-modular icemaker, the motor, switches, and thermostat can all be tested and replaced separately. To reach them, UNPLUG THE REFRIGERATOR. Then take off the front cover of the icemaker and the mounting plate under it. There are usually three switches: The on-off switch is activated by the shutoff arm. The holding switch keeps power flowing to the ejector blades during the ice release phase. The water inlet valve switch controls the flow of water from the water inlet valve. When replacing the thermostat, use the recommended heat-transferring putty between it and the ice mold. To test on-off or holding switch, unmount it and take off leads. With VOM on RX1, probe COM(usually separate from and on the side of the switch) terminal and other two terminals in turm. Look for zero reading on one terminal, infinity on the other. Push button on switch in and retest. Look for reverse readings.
To test thermostat, unmount it, disconnect its leads, and let it warm to room temperature. With VOM on RX1, probe both leads. Look for infinity reading. Place thermostat in a working freezer, and test again. Look for a zero reading.
To test water inlet valve switch, unmount it and take off leads. With VOM on RX1, probe both terminals. Look for zero reading with button out, infinity when you push button in.
To test motor, trace and disconnect motor leads. With VOM on RX10, probe both leads. Look for a reading indicating significant continuity. Replace if infinity or zero.
Posted on Jul 20, 2008
Anonymous
SOURCE: GE MODEL GSH25JSRF-SS PROBLEM HELP PLEASE
I had the same problem back in March. First the water and ice dispensers stopped working, then the clicking started and the compressor wouldn't turn on. I replaced the circuit board and everything started working again, until today. This is a very common problem with the circuit board on these refrigerators. Do a search for "GE circuit board" and you'll see what I mean. GE issued a service bulletin to its technicians that this service should be provided free of charge, and anyone who already paid to have the circuit board replaced will be reimbursed. I wish I would've known about it 6 months ago. I will be calling GE Consumer Affairs on Monday to get this resolved.
Posted on Dec 13, 2008
peyton32034
peyton thompson
  • 410 Answers
SOURCE: Model is GSS25WGMD WW No cooling in freezer or refrigerator
look for ice or forst build up on the rear wall of freezer compartment, sounds like you may have a defrost problem. this will affect temps in freezer and refrig. the most common def problems for GE are bad defrost heaters. these are model specific and fairly easy to replace your self. i got this part number form Sears.com WR51X10055 good luck peyton
Posted on Jan 20, 2009
Anonymous
SOURCE: ge model gsh25jfrfww not cooling just clicking
Replace the main board on the back i got the part for $130 at a wholesale parts store
Posted on Mar 06, 2009
My GE Profile Refrigerator (model PDS20MBSBB) is making a clicking noise. The thermostat display turns off while this happens. When it comes back on the fridge gets really cold and then slowly gets
needs new control board wr55x10942. condensing fan not running or running slow. it get to hot then the compressor relay cut off compressor to protect it once cooled down enough it starts back running.
Oct 09, 2014 | GE Refrigerators
Compressor doesn't start when fridge is plugged in
The board or the cold control thermostat depending on model is bad. If it has a board, that Board most likely also controls defrost which may be why your coils are feeezing if Board is bad.
Oct 22, 2017 | GE GSL25JFPBS Side by Side Refrigerator
Ice machine not making ice
You will have a 60-90 fill cycle, then circulate, then another 60-90 fill, then on to ice making. When Ice making starts all remaining functions come on, such as the condenser fan, and compressor. Check for these functions after the initial fill/rinse/fill has finished. if the condenser fan comes on but the compressor does not, you very well may need a control board located behind the on/off switch panel. With constant heavy loads/usage, and or a dirty condenser coil the compressor relay solder joints often become weak and short open on the board, this can sometimes be fixed by just cleaning and re-soldering the relay joint on the board. Pleazer Appliance...
Feb 02, 2014 | GE Monogram ZDI15C Automatic Icemaker
GE side by side fridge HSS25IFMDWW burnt pin on relay on main board and compressor not running. Tested compressor and it runs okay. What would cause the burnt pin?
Most times the motherboard is the problem that causes the solder to melt from a defective relay. You will need to inspect the compressor start relay and capacitor to insure that they did not cause the relay on the board to overheat. Also check that you have 12 volts dc going to the evaporator and condenser fans while running because if for some reason the fans are defective and you change the motherboard while one of the fan motors are defective your new motherboard again can be damaged. Here is a link to a=> Artica/Profile Service Manual
Here is a motherboard test photo=> Artica Profile Tech Sheet I will be glad to help answer any questions you may have Thanks Sea Breeze
Aug 28, 2012 | GE Refrigerators
GE Profile - model PDS20SBSALSS - constant clicking noise
The clicking is the compressor trying to start. If the compressor is extremely hot, try allowing it to cool. The condenser fan should run even if the compressor is out on overload; that may be the cause of the compressor failure. Check the supply to the fan and replace it if it doesn't run.If the compressor has been overheating for some time, it may be damaged and also need replacing.
Jun 13, 2012 | GE Refrigerators
My GE GSL 25JFPABS Refrigerator failed yesterday. No Comressor no evap or condensor fan
Fan motor starts with the compressor. Sounds like you need a main board and condenser fan motor. Call GE. It might be covered under warranty. A known issue with certain models. You will also need serial # if you call.
Mar 23, 2017 | GE Refrigerators
Panel between doors is very hot-compressor is hot. With compressor running fan is not. There is 32V AC at the fan connection, but the fan says it is a 115VAC
Good day,
First step. Unplug the machine. Your ruining the compressor. If your model has a 115 volt ac condenser motor then that is the only voltage it will run on. If this has been going on for a while, good chance the condenser fan motor is terminal, if not near so.
The first thing is to find the complete model number, style and age of the machine. Could be the motor is controlled by a circuit board, but without that this is as far as we can go.
P.S. Check you meter in a wall socket, to verify it is reading properly.
Apr 03, 2010 | KitchenAid Superba Architect KSCS25INSS...
GE side by side TFX22RLC
If the condenser fan is not running while the compressor is running could damage the compressors overload. Yes it's a serious problem if not repaired soon. (Unplug until repaired.) This can cause a weakened internal overload inside the compressor. Thanks, Sea Breeze
Sep 21, 2009 | Refrigerators
Always defrosting GE Model 20
clean the condenser coils at the back and make sure the condenser fan by compressor is running if is not running you mightg need to call a tech to trouble shoot it or if you want repl both the motor and main board like i said you might need a tech to trouble shoot it
Oct 16, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE G.e Refrigerator Wr55x10942 Motherboard Main Board Logo
522 people viewed this question
Top Refrigerators Experts
Ron Rak
Ron Rak
gbob59
