Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Konica minolta c350 doesn't working in windows 8
Posted by Shylu Surag on
Adorjani Laszlo
  • Konica Minolta Master
  • 1,316 Answers
Download the PS version for printer driver on to konicaminolta support.
Posted on Mar 22, 2013
5 Related Answers
Anonymous
  • 214 Answers
SOURCE: Konica Minolta biz hub c350 malfunction code c-0b4c
C0B4C Finishing option Exit Motor malfunction
Try reboot holding utility key down and do trouble reset, if it doesn't help then there is something wrong with exit motor, call for service
Posted on Dec 07, 2007
Anonymous
  • 589 Answers
SOURCE: copier malfunction
Code C0F36 is a low toner density error on the black developing unit.
Was it asking for black toner before this code appeared?
Posted on Feb 10, 2008
Anonymous
  • 167 Answers
SOURCE: I need the default ip address for the Konica Minolta C350
Press the Utility/Counter button.
Administrator Settings - password is 12345678
Network settings
TCP/IP settings
Posted on Feb 17, 2009
Anonymous
  • 3 Answers
SOURCE: c350 malfunction code c-0501
After replacing the fuser unit, if you got a c0501 code you must open the front door where the toner is. On the right side (hinge side) next to the black toner and drum unit there is a plastic pannel/cover. In the lower portion of that pannel there is a hole where a trouble reset switch is loacted. With a flashlight you may be able to see it. You are ment to use a thin screw driver or the like to push the button. You do this while the machein is on and desplaying the code. As soon as you press the button the copier will clear the code and start warming up. Thats it! If you are un certin of the button placement you can take out three screws from the pannel and loosen one screw from the pannel above it and and pull the pannel off the unit. You will see the board and it is the button on the (left), as there are two of them. Tho you only have access to the one thru the cover.
Posted on Oct 18, 2009
mike roark
  • 158 Answers
SOURCE: How do I install Konica
To setup LPR Printing, perform the following:
For Windows 2000/XP/Server 2003:
1. For Windows 2000, click the [Start] button, point to Settings, and then click Printers.
2. For Windows XP/Server 2003, click the [Start] button, and then click Printers and Faxes.
3. Right-click the icon of the installed printer, and then click Properties.
4. On the Ports tab, click the [Add Port] button.
5. In the Available Printer Ports list, select Standard TCP/IP Port, and then click the [New Port] button.
6. When the Add Standard TCP/IP Printer Port Wizard starts up, click the [Next] button.
7. In the Name of printer or IP address box, enter the IP address for this machine, and then click the [Next] button.
8. Select Custom, and then click the [Settings] button.
9. Select LPR, enter Print in the Queue Name box, and then click the [OK] button.
10. Click the [Next] button, and then click the [Finish] button to apply the setting.
Posted on Oct 24, 2009
Konica minolta bizhub c350 error codes c-0510
eror code c-0098 meaning ??????????????pls tell me the solution
Jul 31, 2012 | Konica Minolta Bizhub C350 Digital Copier,...
I am trying to connect my laptop windows 7 to our office konica minolta C350 printer, but am not having any luck
You will need to download Windows XP 32 or 64 bit drivers. You can get them from kmbs.konicaminolta.us
Jan 07, 2010 | Minolta C350 Printer
Konica minolta c350 troubleshooting
see konica minolta sit support and driver put ur c350 and downlode
Nov 18, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Printer not receiving information from computer
I guess you mean the c350 is not printing while Windows said the job has been sent? If so, it may have changed IP Address from the time you first install the Printer on Windows. Check the Ports setting of the c350 printer! e.g. d53b002.jpg
Network Pritners should have Static IP address or at least a reserved DHCP IP Address. Logon to your Router, check the MAC Address of the c350 and reserve/assign it a IP Address near the end of the DHCP range. Save the Router configuration and power cycle the c350. Confirm IP Address changed to the reserved IP.
Then you have to change all the PC's Printer Configuration of the c350's Port to update the reserved/assigned IP. Or remove the c350 from Printers and Faxes, then run the printer setup software again.
May 23, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
I can't print from IMac to konica-minolta buzhub C350
Go to konicaminolta web site and download a mac driver. and install it to Imac. Make sure to download OS10.4 or higher.
May 11, 2009 | Minolta C350 Printer
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
970 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
