When I start up the machine the pump does not work,and at the display appears Coffee Boiler Filling Error. Please help me!!!!!
SOURCE: Boiler has quit working
Check to make sure that there is water in the boiler by either checking the sight glass then rocking the machine to see if the water level bobs up and down, then check the thermal reset switch on the left side of the machine above the element. Make sure there is water in the boiler before pressing reset and turning machine to number 2. After machine heats up make sure pressure does not go past 1.5 bars on the gauge. If it does then the p.stat needs to be replaced.
Testimonial: "Thanks, I will give that a try.... I appreciate your help....."
SOURCE: Filling the boiler tank
Sounds like the auto fill circuit is not engaging or is getting blocked, usually when all the lights in front is flashing, machine is saying it is not getting water.
SOURCE: It is making a very
my astoria espresso machine is also making a loud noise when running ( brewing espresso ) ...it only happens under pressure and does NOT happen if its running but there is no espresso ( not under pressure ) .... my guess is that its the solenoids.... if you find out what is causing your problems please let me know...
[email protected]
