Children have pressed combination buttons on remote, and now, it does not display the tv channel numbers, volume level, or any of menu list ?? Unable to see any settings ? The Owner's Manual is of no help.
SOURCE: ESA ET413E LOST INSTRUCTION MANUAL, NO SELECT KEY!
when picture is displayed on your tv after pressing menu,press the channel up/down button on the remote or tv. there can also be a button that shifts right to left. this may hilight the the settings you want to change. if the up/down button scrolled you thru the settings, then the right/left buttons should change the settings.
hope it works
wg
SOURCE: Lost the manual. Can't re-program remote control. Need step-by-step
http://www.rca.com/documents/15128800_201059_25.pdf Hope this helps :)
SOURCE: Sylvania SST4272
I had the same problem with a Sylvania SRT2227S. I kept trying to fix it using the remote but after reading your posting I pressed the Volume (down) button, which cycled through the same menus you mentioned. Then I pressed the Power button on the TV and that fixed it.
The problem started for me when pressed PIP, CC, and Guide buttons on a Philips universal remote control. My TV does not support these functions and it seems to put it in this "service mode". Now I can fix it by pressing Volume (down) or Menu then the Power button on the TV (do not use the remote as it is useless when the TV is in this mode). I hope this works for you too.
SOURCE: how to turn off channel number displayed in TV screen
Press " i " (info) button on Sony TV Remote so on-screen display will disappear.
