I been using my laptop with the tv a few times but now when I connect the laptop to it the tv wont connect to the laptop. I try the laptop with my pc monitor and it works ok. What could be the problem?
SOURCE: Connecting LG 50PC3d to Computer
It sounds like you have the resolution of the PC set to an incompatable format for your TV.
SOURCE: RBG-DTV
The video out resolution through the port may not match what is supported by the TV.
SOURCE: connecting laptop to lcd
You may need to use the S-video cable for video. Make sure video mirroring is disabled on the powerbook. Also, make the external monitor the primary display by dragging the menu bar to it in Displays preferences (Mac OS X) or the Monitors control panel (Mac OS 8 and 9).
SOURCE: my lg 32lh20d-aa wont show up any other input
Please follow this guide to unlock your tv :
www.ehow.com/how_4488981_unlock-tv.html
Regards, Jay
SOURCE: Trying to hook my home
Connect VGA (D-sub 15 pin) cable from PC to TV (RGB PC) input jack. Connect audio cable from PC to TV. Set screen resolution on PC to be compatible with TV, such as 800 X 600 or 1024 X 768 etc. Select on the TV, the PC INPUT using the TV remote when ready to use as monitor.
Under PICTURE on the TV select SCREEN (RGB-PC). You can AUTO-CONFIG or you can set resolution manually to the same you set PC to. Other adjustments can be done here as well to get optimum picture on TV from PC.
My laptop is a Toshiba and it only have a VGA out and the LCD tv have a vga input. At first when I connected the laptop it worked for a few times without problem, but then this time it just would not connect .
