Question about Amerock CM8701BB Decorative Hinge, Double Demountable, Overlay 1/4, Burnished Brass
Video on how to install double demountable hinges
I installed the Everbilt double action spring hinge. A YouTube video said the hinge needs to be oiled; the instructions do not say so and I see no hole for oil.
While the door is opening, part of the hinge as seen from the top will remain stationary and part will rotate with the door. Between them is where you'd put a few drops of oil. There's probably a couple of places this movement occurs. However, this probably won't be necessary for years but can't do any harm, especially if they get rained on.
Mar 13, 2017 | Miscellaneous
How to adjust double glazed window hinges
you dont show a good angle of the problem area in your video, but I would suggest unscrewing the hinges, reattatching the 'keeper', and re- screwing window hinges
Mar 09, 2013 | Hardware & Accessories
Demounting SATA Optical Drive
Remove the case facia, it's a bit tight so pull firmly but gently.
Then release the green quick fit clip and you can slide the drive out.
Apr 16, 2012 | Acer Veriton M464 (4718235937997) PC...
Change sceen
A replacement screen maybe available from this WEB site.
www.lcdparts.net
The screen is removed by undoing the hinge screws, careful unclip the video connector from the motherboard.
Keep the screws together as you remove them so you will know which screws are needed to install when you fi the new LCD screen
Undo the screws that hold the bezel that surround the LCD screen, then remove the bezel (it may be also held in place with double sided tape).
When the bezel is removed the LCD screen is secured to the hinge assembly by more screws around the edge of the LCD screen.
When you install the new LCD screen, reverse the order you took in removing the LCD screen.
These WEB sites may assist you in repairing the LCD etc.
Replacing Display hinges
http://www.laptopparts101.com/display-screen-hinges/
Laptop repair info
http://www.laptoprepair101.com/
Feb 11, 2012 | Computers & Internet
Dear Sir, I am having Dell inspiron windows 7 ,I installed Brian lara cricket 20007 fully , but when we open the game it shows error .i.e.. emulate detected software.
re check that you have copy pasted the crack...
after complete installation.. try playing the game after demounting the CD image..
Jul 23, 2011 | Codemasters Brian Lara International...
Door to oven does not close completely - how do I access the door hinge to check or replace it?
Open oven door. Flip metal holder down at hinge to lock hinge. Lift door with hinge attached up slightly and off oven. Reverse to re-install door, making sure notch at bottom of hinge is hooked in frame of oven properly.
Jan 02, 2011 | GE JTP45 Electric Double Oven
Dell 3010cn printer, says reseat drum contact support. I took drum out and put it back in but don't see anything wrong. It feels secure and I restarted the printer, but no luck.
Hello sir; Pull out the drum cartridge, look around the cartridge you will find a small memory chip, remove it, shoul d take care this problem.
Nov 28, 2009 | Dell 3010cn Laser Printer
How shall I change the switch for the windows in the doors. do I have to demount the insida doorpanels? How do I demount these panels if it is necessary? Eric
You can pull that switch straight up if you have a tool to get underneath the rocker portion of the switch. to re-install, you need to use your fingers and recompress the plastic, because it is a very tight fit
Jul 15, 2009 | 2000 Volvo V70
Missing part on a Phil and Teds E3 inline double jogging stroller
I just ordered the part over the phone from Regal Lager (the US distributor for Phil and Ted's, I think...) at 800-593-5522. It was $4 per hinge plus shipping. Just tell them you want to order the Phil and Ted's E3 part from the component list and give them the part numbers from the list here. Good Luck!
Dec 11, 2008 | Phil & Teds E3 - Charcoal Black Jogger...
Amerock CM8701BB Decorative Hinge, Double Demountable, Overlay 1/4, Burnished Brass Logo
778 people viewed this question
Top Amerock Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you an Amerock Hardware and Accessory Expert? Answer questions, earn points and help others
