SOURCE: amp
There is no reset button. If you disconnect all of the speaker wires from the amplifier's speaker terminals and unplug the RCA cables, does the protect light still come on (I assume that you've already replaced the fuse)?
SOURCE: rockford fosgate bd1000a1
There is nothing to reset on this amp, it has no microprocessor.
Resets for electronic equipments are for clearing any software glitches that the microprocessor uses to do complex functions. I have only seen microprocessors in a couple of Kenwood amplifiers, and I have fixed many Fosgate amplifiers including this model. If you are not gettng any sound from it, you may have a blown channel. It is the most common failure I have seen in these. If that is the problem with yours, you need to take it to a service center that works on Rockford Fosgate amps, they have output transistors that are mounted on what is called a "mesha rail" and you can not change out just the 1 or 2 that are shorted, you must replace the entire rail because the transistors can not be removed from the rail and there are no generic parts for them as well.
I hope this helps you with your problem, deciding what you can do with it. It is a very good amplifier and in most cases it is worth the repair cost. You can not get a different amplifier of the same quality for less than the repair cost which usually runs about $125 at my shop.
Let me know if I can be any more help to you.
Dave
SOURCE: Rockford Fosgate 120a2 amp
You can get it from Rockford.
Let me know if you need any help repairing it.
SOURCE: How much would installing a headunit, amp, and subs usually cost?
hows it going so you need it to be installed or you can install this yourself? well the best bet fund to get stuff done cheap is t get the stuf you will need to do an install like a install wiring kit and tools and post a installer help on craigslist.org iin your local area would be the cheapest way or just go to your local audio stereo shop thanks again and i hoope this help have any more questions please feel free to contact me if you need a step by step install i can help you in that and save you big bucks thanks again. always forward jcbproducts
SOURCE: Rockford fosgate 800 a2 amp power?
Hello desperate2le,
Watts delivered is a function of the voltage times the current. If the amp was 100 percent efficient, it would need 33 amps at 12V for 400 watts. At 14.4V, it would only need 28 amps. Of course, amplifiers are NOT 100 percent efficient, only about 50-60 percent in many cases, but somewhat higher for monoblocks, maybe 80-90 percent. So you're looking at a fuse in the 60-80A range. In the absense of a specific fuse size from the manufacturer, I'd start the primary fuse at a 60A and if the amp blows it on power up/immediately/frequently, move up to an 80A.
All of the Rockford-Fosgate 2-channel bridgeables I've ever seen show using the left positive (+) and the right negative (-) for bridging. But if it's not shown right on the amp, I'd call or email RF for the correct connection. The new amps do show it.
Hope this helps.
