2000 Chrysler Town & Country Tail lights and dash lights won't work
SOURCE: Describe your 2004 Chrysler Town &
u may try checking the wirings of the front blower, it may be corroded thats why its losing contact, hope this helps
SOURCE: Describe your 2000 Chrysler Town &
Look for a blown fuse or bad relay for the a/c in the front fuse box. If replacing fuse and it blows again, then there is a short circuit on the load side of the fuse which goes to the a/c compressor clutch. If fuse ok, try another relay to replace the possible bad a/c unit. The engine computer controls this relay. It also receives air temperature sensor reading from cold air path.
SOURCE: Describe your 1996 Chrysler Town &
HAVE SOMEONE EXTRACT THE CODE FROM THE CAR'S COMPUTER. IF THERE IS A CHECK ENGINE LIGHT ON THEN THE PCM HAS A CODE STORED ON IT. IT SOUNDS TO ME LIKE A THROTTLE POSITION SENSOR, BUT JUST CHECK THE CODE TO BE SURE. SOME OF THESE CAN ALSO HAVE A BAD IDLE AIR CONTROL VALVE. I HOPE THIS HELPS YOU TO FIND THE PROBLEM. PLEASE KEEP ME POSTED, THANKS FOR USING FIX-YA. GOOD LUCK
SOURCE: The turn signals don't work most of the time,
check your accessory relay. Hopefully it isn't your power module. $1000 fix at chrysler. :(
