5536/5236 series
SOURCE: Acer Aspire 5715Z/5315 Series Laptop
Sorry, no easy fix. You will have to replace the drive.
SOURCE: acer aspire 5315 laptop cd/dvd drive stop working like there was none
This will be one of two things, 1- a driver glitch, you will need to uninstall the drivers for the cd/dvd drive from the device manager, then reboot. The machine will find the drive and reinstall the drivers automatically. This will fix it if it's a driver problem. You can also try any updated driver utilities, or patches for the drive from Acer's support site. 2- the cd/dvd drive has failed and needs replaced. These are basically plug and play devices, they either work or they don't, so a majority of the time when the machine stops recognizing the drive, it's because the drive has malfunctioned. Unfortunately, these drives are considered sealed units and replacement parts aren't available.
SOURCE: Acer Aspire 3100 series. Display screen getting dark
This is such a user error. I had the same problem on my 3100-1718. It was as simple as holding down the Fn key and using the left and right arrow keys to change the brightness... I am a goofball for ever letting this stay dark for a month !
SOURCE: My Acer Aspire 5100 Laptop wont detect the hard drive
If it works on another computer then either the ide cable in the acer is bad/loose at either end or the ide controller on the motherboard is bad. I would try a known good ide cable first as if this is the problem it is fixable alot cheaper than a motherboard. Hope this helps.
SOURCE: cant turn on webcam on acer aspire 5534 series laptop
Is there a system tray icon that has camera disabled?
