Fujifilm FinePix JV300 Digital Camera - Pink 14MP, 3x Optical Zoom 2.7 inch LCD Screen Logo
Anonymous Posted on Mar 21, 2013
Finepix jv300 my camera only switches on when it is connected to the charger. its also not saying battery full. when take it off charge it will not switch on at all.
I lost my fujifilm finepix jx 400 battary charger and i want to use my usb cable to charge it is it possible i plug it but it seems doesn't charge
The JX-400 is a camera, not a battery charger. Connecting it to a computer's USB port simply drains the battery faster since the camera has to expend juice communicating with the computer (even if only to say it has nothing to say).
One source for a battery charger is http://www.overstock.com/Electronics/BasAcc-Battery-Charger-Set-for-NP-45-Fuji-FinePix-S610-J110-J150W/7124327/product.html?searchidx=3
Feb 15, 2014 • Cameras
2helpful
I need to download a driver for my FinePix JV300
You don't need a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
2helpful
2helpful
How do i charge a fujifilm finepix jx
Remove the battery from the camera, put it into the supplied charger, and plug the charger into a power outlet. Full details are on page 5 of the manual.
15helpful
2answers
How long do you charge fujifilm JV300 camera?
Remove the battery from the camera, put it into the supplied battery charger, and plug the battery charger into a power outlet. The charging is complete when the light on the charger turns from orange to green.
Fujifilm battery fully charged but camera says no charge or very little. Just bought a new Duracell Battery and Charger for my Fuji FinePix J10 Camera. Used the charge on the battery in the camera from...
Well you mentioned that it worked fine yesterday with the battery out of the box. That should tell you that the camera and the battery are both fine. The issue is likely the charger itself. Try recharging it again, and double check that you inserted the batteries correctly, and that any switches (such as for 2 or 4 battery charge) are set in the correct position on the charger. If this doesn't work, take the charger back to the store for exchange/refund as defective.
Will the battery in my fuji finepix f470 charge when the camera is connected to my laptop (via camera usb used to get the photos) or do I have to use the charger that came with it and plug it into the...
The camera will not charge through the USB. In fact connecting the camera to a computer drains the battery faster, since the camera has to expend juice communicating with the computer (even if only to say it has nothing to say). See page 10 of this manual.
Fuji finepix a330 digital camera says "low battery"
To help rule out if the battery, camera, or even your charger I would suggest to first clean all the contacts. This can be done with some rubbing alchol and a q-tip, make sure you get the contacts in the camera, directly on the battery, and your charger. Wipe off any excess alchol and let it sit for a minute or two so the alchol can evaporate. Give the battery a good charge and see what happens. Where did you purchase that replament battery? If what was under 10bucks I would suspect it's the battery, there are a ton of crap battery's hitting the market, always stick with name brand. Another possibility is that the charger could be sending the wrong voltage to the battery causing inproper charging, or even the chargers power cord could be sending the wrong voltage to the charger. Anyway I'm done rambling, It's 12:15am and I have a 70hour week starting in 6 hours so i'm outta here. Hope this helps. And here's a link to your manual if you need it: http://www.fujifilmusa.com/JSP/fuji/epartners/bin/A330A340Manual_1.pdf L8R Good Luck
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
