The VSD Fault G1F032 on an Ingersoll Rand 110 kW VSD (variable speed drive) likely indicates an issue with the drive's DC bus. This fault code indicates that the DC bus voltage has dropped below the acceptable range, which can cause the drive to trip or shut down.
Here are some steps you can take to troubleshoot this fault:
Check the incoming AC voltage to the drive to ensure that it is within the acceptable range. Low voltage or voltage fluctuations can cause the DC bus voltage to drop below the acceptable range.
Inspect the DC bus capacitors for signs of damage or leakage. Damaged or faulty capacitors can cause the DC bus voltage to drop and trigger the fault code.
Check the connections between the DC bus and the drive's power modules. Loose or faulty connections can cause voltage drops and trigger the fault code.
Check the drive's cooling system, such as the fans or heat sinks, to ensure that they are operating correctly. Overheating can cause the DC bus voltage to drop and trigger the fault code.
Consult the drive's manual or contact the manufacturer for additional troubleshooting steps or assistance.
It is important to take caution when working with electrical components and ensure that any modifications or repairs are done by a qualified technician.
Take it to a qualified repair shop, unless you know about C.A.N - controller area network - serial data communication network between modules . U1900 -20 - ic states that one of the 8 or 10 or more modules on your vehicle has stopped talking .
U1900
CAN Communication Bus Fault-Receive Error
RCM
REPAIR all other DTCs first. CLEAR the DTCs. CYCLE the key OFF then ON and wait 10 seconds. REPEAT the self-test. If DTC U1900 is still present, REFER to Section 418-00 .
U1900
Occupant Classification Sensor
U1900
SJB
U1900
DVD Player
U1900
Audio Control Module (with Navigation)
U1900
U1900
SDARS
U1900
Retractable Running Board Module
U1900
CAN Communication Bus Fault-Recieve Error
ABS Module
U1900
Parking Aid Module
U1900
4WD Control Module
U1900
Instrument Cluster
U1900
CAN Communication BUS Fault - Receiver Error
DSM
apers ???? What's this ?
U1900
CAN Communication BUS Fault-Receive Error
ABS Module
U1900
Instrument Cluster
U1900
Trailer Brake Controller
Your best bet, take it to a qualified repair shop.
U1900
Vehicle Security Module
U1900
4WD Control Module
U1900
Parking Aid Module
U1900
DSM
U1900
Instrument Cluster
If the 4X4 light is not flashing at key ON, REFER to Section 418-00 .
If the 4X4 light is flashing at key ON, REFER to Section 308-07A .
U1900
Power Liftgate Module
U1900
Stability Assist Module
U1900
Air Suspension Module
which module won't communicate ? need a up scale scanner to communicate with all the modules on the vehicle. Do you know what C.A.N - controller area network is ? Serial data bus (network) All the modules on the vehicle share data on the network . U code's indicate a problem with the network .
