Question about Dell PowerEdge 1600SC Server
Fan error reported - Dell PowerEdge 1600SC Server
Posted by martin taylor on
Jose Diaz
  • Dell Master
  • 2,878 Answers
Re-seat it, If still failed, replace it.
Posted on Mar 28, 2013
System shut down suddenly while playing music , when i restart f61 error appears and suddenly shut down
Most users report this to be a fan error. It tends to blocked with dust and fluff. Cleaning the fan solves the problem.
Dec 06, 2016 | Audio Players & Recorders
What does this error code mean...4SNS/1/C0000008 TL0P==124
It's a temperature sensor error, usually the fans run at maximum rpm when this happens. The error indicates the LCD temp sensor is either reporting out of range data, is disconnected, or has failed. It is probably a damaged or disconnected sensor cable. A disconnected or missing sensor would simply force the fan(s) to run fast to protect the system.
Oct 27, 2012 | Apple 21.5" iMac Desktop
Installed hallmark card studio 2011 upon launch keep recieving send error message to microsoft.
The installation must have gone wrong somewhere, Uninstall and install again.
If the program works anyway. Just disable the "Send Error Report" message:
To access the settings for the reporting feature:
  • Click Start.
  • Right-click My Computer, then click Properties.
  • Click the Advanced tab.
  • Click Error Reporting.
To configure the error reporting feature:
  • By default, error reporting is enabled. To disable it, click Disable error reporting. To continue to be notified when errors occur without being prompted to report the errors, click to select the But notify me when critical errors occur check box.
  • Specify whether you want to use error reporting for the Windows operating system, for programs, or for both Windows and programs.
  • To report errors only for selected programs, click Choose Programs, click All programs in this list, and then click the programs that you do not want to include.
  • To add a program that is not listed, click Add, type the name of the program, or click Browse to find the program on your computer.
Mar 01, 2011 | Computers & Internet
It shoes printer error 57.1 on display of HP Laserjet 5100tn
Printer fan is reporting an error.
It could be clogged or busted.
The fan is found on the right side of the printer. There is a whole bunch of ventilation holes in the cover. Can you feel the fan blowing air?
Feb 14, 2011 | Office Equipment & Supplies
Hi My HP proliant dl360 G3 server reports an ok stauts on the cooling section of the system manager but for some reason the next day it reports an insuficient cooling problem and fan failure and reboots...
From my experience, this is an indication that your fans need replacing. If your system manager is working properly, at night if your system is not use much, the manager will put the system in a low state of operation, almost like hybernation. When a request come in to 'wake-up' the system, the fans do not spin fast enough to cool your system properly thus the errors.
Replace the fans, recheck your settings in system manager making sure the manager software is monitoring the cooling and not the os. This should solve your issue.
Good Luck
C2Solutions
Jan 13, 2011 | HP Compaq ProLiant DL360 G3 Server
IBM Lapyop T42-message"Fan errors" does not turn on
your cooling fan is reporting as damaged you need to replace the fan unit (cooling pad as well) likely service is required and unless you want to disassemble your laptop a service center would be better suited for this job.
Dec 13, 2008 | IBM ThinkPad T42 Notebook
Check cpu fan computer error
You can simply disable the reporting feature from the CMOS of your computer but that is not advisable, try changing the exhaust fan of your cpu to correct the rpm then resolve the error
Nov 16, 2008 | Gateway Computers & Internet
I have a Samsung Washer/Dryer (WD-J1255) When trying to complete a dry cycle, "HE2" shows on the screen. There is no such error code in the manual. The machine has been reset and the same happens...
Samsung reports FE is "FAN ERROR".
Samsung replaces the internal die cast fan-heater unit.
If not under warranty, as DIY try unpluuging the unit and removing the top cover. Remove the aluminium die cast "Assy Duct Scroll" which is on the RHS and contains a fan and a heater. Dissasemble by removing screws and remove the clogging by detergent foam and lint. Use vinegar as this dissolves the sludge. Rinse and check that the fan can spin freely. Note that the fan motor or heater could have burned out. However it is likely that a heat sensor that reported FE can caused a shutdown due to over heating.
If cleaning and replacing does not help a new unit may have to be sourced.
Note if exensive corrosion is present the unit will have to be replaced.
Note that use of foaming detergents or too much detergent will cause this problem.
Jul 24, 2008 | Samsung Washing Machines
Optra 642 series
Is it only that document or from any OTHER doc source, word, excel etc.....
Nov 13, 2007 | Lexmark T642 Laser Printer
Dell PowerEdge 1600SC Server Logo
32 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
