Am Baker from Sudan, am using aspire 5349 recently i bought a projector(accer x112) but i cant use it due to that problem when ever i connect it displays the information but i cant see it on the screen of the laptop, waiting for help thanks.
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 ASUS and Dell = Fn + F8
SOURCE: My Acer Aspire 7720 cannot connect to the internet
go to network and sharing center. it should be where you click on the internet icon down at the bottom in taskbar right side. when it opens try setting up a new network. if that don't do it check to make sure your wi fi is on or needs resetting. also on that page in the network center is a pretty good troubleshooter. good luck
SOURCE: i have acer aspire 4720 laptop. when i am
Did you press FN key+F5?
Please rate my help++++Thanks for using FIXYA
SOURCE: I have an Acer Aspire 5515 laptop. My computer
Wow this is tuff,
Setting from keyboard, possibly.
Software, not likely.
Video Card, possibly.
LCD Screen, very likey.
But with no screen you options at home are limited.
There is a setting on laptops that allow you to send the video output to an overhead projector and cuts the laptop screen off. However, when you re-boot it usually defaults to the screen.
I betting on a screen failure. You may want to take it to a PC Repair shop. Or, buy one here,
http://www.hootoo.com/154-inchs-acer-aspire-5515-laptop-lcd-screen-panel-p-11162.html
http://www.amazon.com/ASPIRE-LAPTOP-SCREEN-SUBSTITUTE-REPLACEMENT/dp/B003XHDARC
Good Luck
SOURCE: I've just bought a new
Hi jennylewry...
To fix an unresponsive touchpad on your laptop, reactivate it by using the Function key on the keyboard and the Fn key.
This process is different for each computer manufacturer.
If unsure which Function key enables and disables the touchpad, try each one at a time and then
attempt to use the touchpad after each one.
A...Locate the "Fn" key of the laptop keyboard.
The "Fn" key has different colored text or the key is a different color.
B...Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
C...Press both the "Fn" and touchpad Function key at the same time to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again.
Note: Mac computers use "F2" to enable and disable the touchpad.
D. Sony Vaio Users: Start>Settings>Control Panel>Double click the Mouse icon.
Look at the top left hand side of the page, at the top and make sure that the "Tapping" box is unchecked, if it is checked then, you will uncheck it.
Please take time to rate me thumbs up
SOURCE: got an acer aspire 5735z laptop, its running but got a black screen
It only means that either the Inverter Cable/LCD cable or the LCD itself is defective, because if you still see the contents of the laptop to an external monitor, then it means that the rest of the computer's components are working.
You can have the Inverter Cable reseated or have the LCD screen replaced. Have it tested by a local technician.
Testimonial: "thank you, thought as much"
