Question about Heavy Machinery
How to change the anvil on jensen 530 chipper
How to change the anvil on a jensen 530 wood chipper
Derrick Schultz
    Top Expert:
  • Heavy Machinery Master
  • 11,405 Answers
Hi there's this website something like
reliable-store and it is very amazing for manual for repairing servicing anything
someone on fixya recommended it to me and I thank him even today
They have full manuals and it's verrrrry cheap and mine
I got free in offers
3rd time I also had an issue with the file so the girl replaced it in 30 mins
there is one more but i don't remember its name it was 2 years back bitman something link this
both very good
Posted on Jan 19, 2019
2 Related Answers
Phil Rivera
  • 83 Answers
SOURCE: my chipper is throwing long chunks of unchiped
Either your blades are dull or the gap between the intake tray by the blades is too far or is rounded off. Many chippers have a plate on the intake by the blades that can be flipped around when it rounds off. Also some have a edge on the other side of the blade so it can be reversed and give you a fresh edge. Be sure to unplug the sparkplugs and remove the key when going into your chipper to ensure no one can start it when your in it. There is usually a lock bar to keep the blades from moving.
Posted on Mar 31, 2009
ChasnMD
SOURCE: looking for manual for troy-Bilt super tomahawk wood chipper
here is the link to the manuals for the 47266 http://www.brentchalmers.com/
enjoy :)
Posted on Sep 13, 2009
What year is my wood chipper? I purchased a Craftsman 8hp wood chipper-shredder that is silver-gray in color and all metal in construction with a Briggs & Stratton 8hp motor. The B&S motor is...
The B & S Code is the date of Mfg. This engine was built in 1994 (first two digits rep. the year), Sept.( the next two digits rep. the month) and the second day of that month. Your engine was built on Sept.2,1994. Your chipper may be one year newer as the engine had to be installed after the date of mfg. Your welcome
From North Carolina
May 17, 2011 | Heavy Machinery
No brad
Your anvil is not returning to the home position to allow the brad to index into the receiver. Try and push the anvil up all the way to the home position. If that works, then you need lubrication, new return spring, etc. All related to the anvil firing.
Jul 02, 2009 | Craftsman Nailer Kit, Palm Air Driver
10 hp Troy Built chipper pull start frozen
If a branch was already being chipped when it ran out of gas...you must clear the hopper of any chunks of wood in it. Pull the plug wire and use a metal pry bar to dislodge any pieces of wood. when the flywheel runs free, put the plug wire back on and the choke on. Try it now!!!
Jun 14, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Looking for manual for troy-Bilt super tomahawk wood chipper
I have the both the manual and parts catalog for Troy-Built 8hp Tomahawk, can send them to you for the cost of coping and postage if you haven't found them yet.
Ron Bowman, [email protected]
Apr 25, 2009 | Briggs & Stratton Heavy Machinery
What is a chipper?
Most of our industry refers to chippers or chipper-shredders as pieces of equipment that can handle both wood and leaves. These machines have both a chipping device and a leaf-shredding mechanism. This mechanism is basically a hammer mill, cylinder or drum with a series of pivoting flail-type knives. The chipper-shredder usually is a smaller machine and may include a vacuum to clean up leaves. These machines can be self-propelled or stationary. Most chippers are disc-type, consisting of a large, heavy, rotating disc with knives mounted to it and are for chipping wood only.
Aug 27, 2008 | PDP Systems 1.5 Horsepower Electric Wood...
Chipper Maintenance
Maintenance (excluding the power plant) Your primary maintenance concern with chippers and shredders is their knives. You can re-sharpen chipper knives, whereas you can reverse shredder flail-type knives when dull but you can not re-sharpen them. You must sharpen chipper knives with special sharpening equipment because they are made of high-carbon steel. Maintaining sharp knives can lengthen their life and the life of the machine by keeping power requirements low. An over-dulled or chipped chipper knife will need extensive sharpening, which will remove a large portion of the blade. This obviously will shorten its life. As soon as a blade is slightly dull, you should sharpen it to minimize the amount of blade-material that you remove. All knives need sharpening at the same time to keep them in balance-even if only one is worn or chipped. Also, you must use matched sets to keep the knife the same distance from the anvil for proper chipping and feeding. After removing the knives, clean the area where they are fastened with a wire brush to make sure they will align correctly. Be sure to torque the knife bolts to their proper specifications. You will need to examine the anvil and be sure it maintains a good, square edge. Occasionally, you may need to remove and sharpen it.
Aug 27, 2008 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Chippers and Shredders safety tips
Make sure that the machine has come to a complete stop before removing access panels. When performing maintenance on the machine, shut off the engine, remove the key (if electric start) or temporarily disable the machine. Always feed material butt-end first. Feed shorter material into the machine by laying it on top of longer material. Do not feed material that you've raked up or scraped off the ground. You should simply place this material on top of the material that you've already chipped, as it may contain dirt and rocks that may damage the chipper. Chippers with dull knives and anvils do not feed well. This becomes a problem with any machine but especially on manual-feed units. If your operator then tries to force the material into the feed shoot, he or she creates a greater danger of slipping and getting too close to the chipper knives. Do not operate the chipper alone. Always be prepared for a fire or injury by having a fire extinguisher attached to the machine and a first-aid kit handy. It is the operator's responsibility to make sure that flying chips and debris will not harm bystanders.
Aug 27, 2008 | Troy-Bilt® Briggs and Stratton Chipper
Woodchipper support
Deaths have occurred involving the use of wood chippers. Never allow children around or near the area when you are using a wood chipper. No one under the age of 18 should be allowed to use a wood chipper alone.
Aug 27, 2008 | Tanaka TIA-350s Post Hole Digger -...
Wood Chipper how to
Great input tina783. I have just one thing to add. Try to shred the branches within a reasonable amount of time. I found out that with my shredder, if I put older, dried up branches in, it tends to take a lot more time, as well as tosses chips back out at you. With newly cut branches, this wasn't nearly as much as an issue.
Aug 27, 2008 | AMANA TOOL 658060 PRESTIGE FINE DADO SET...
Heavy Machinery Logo
133 people viewed this question
Top Heavy Machinery Experts
Bill Boyd
Tom Chichester
STEVE
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
