Question about MyRete WhosHere
I lost my profile when i change the device - MyRete WhosHere
I lost the serial number from the back of the kurio. How do i reset profile again?
Restore preloaded content after a factory reset ... - Kurio
www.kurioworld.com/k/us/parents/support/afterfactoryreset
When Kurio prompts you to Create a Kurio User Profile, SKIP this step by ... OnceKurio reinstalls all the preloaded content, you will enter the Owner Profile again. ... the same recovery procedure above, but DO NOT factory reset the device.
Sep 29, 2015 | Techno Source Kurio Kids Tablet With...
Ringer is marked as off on my blackberry bold 9700 and i have no sound
Hi,Sound profiles define how your BlackBerry device alerts you of phone calls, messages, reminders, and browser content.
Your device has a Normal sound profile and six other preloaded sound profiles: Loud, Medium, Vibrate Only, Silent, Phone Calls Only, and All Alerts Off.
By default, some of the settings in the preloaded sound profiles are based on the settings in the Normal sound profile. For example, when you change the ring tone in the Normal sound profile, the ring tone in the Loud, Medium, and Phone Calls Only sound profiles is automatically updated. If you do not want specific settings for a preloaded sound profile to update automatically when you change the corresponding setting in the Normal profile, you can manually change the settings in that preloaded sound profile.
You can create custom sound profiles. When you assign a custom ring tone to a contact, the ring tone is always active and does not change when you switch sound profiles unless you switch to the All Alerts Off sound profile. Call and message notifications for your contacts might be audible even if you switch your sound profile to Silent or Vibrate Only.
You can change, rename, and delete most preloaded sound profiles. You cannot delete the Vibrate Only sound profile and you cannot change, rename or delete the All Alerts Off sound profiles. You can change the Normal sound profile, but you cannot rename or delete it because some of the settings in the other preloaded sound profiles are based on the settings in the Normal sound profile.
Sound profiles define how your BlackBerry® device alerts you of phone calls, messages, reminders, and browser content.
Change a sound profile
If you change a setting in a preloaded sound profile that is based on the Normal sound profile, that change will override the corresponding Normal sound profile setting in the preloaded sound profile.
1. On the Home screen, click the Sounds icon.
2. Perform one of the following actions:
* To change the active sound profile, click Set Ring Tones/Alerts.
* To change a custom or preloaded sound profile, click Edit Profiles. Click a profile.
3. Click the application or item that you want to change.
4. Change the notification information.
5. Press the Menu key.
6. Click Save.
7. Press the Menu key.
8. Click Save.
Hope that helped...
Feb 08, 2011 | RIM BlackBerry Bold 9700 Smartphone
I used my gamertag at my mates and now it wonte let me recover it what do i do ?
if you can get a usb (at least 1 gb) and plug it into your friends xbox, you can put your gamertag profile onto the usb and then transfer it manually. this is the safest way. your usb must be configured to Windows FAT32 file system format (devices formatted for use with other file systems might not work). On your console go to my xbox then system settings, then memory. on the storage devices screen select usb storage device. select configure now (note this will erase everything on your usb) then The Xbox console tests your USB storage device to make sure it will work correctly with the console. If your device passes this test, you can use it as a USB memory unit. to get your gamer profile on there go to system settings, memory then the hard drive, select gamer profiles and move your gamer profile to the usb. you shouldnt recover your gamer tag unless you absolutely have to as any achievements or changes you have made since the account last connected to Xbox LIVE will be lost during the recovery process. once again do not recover your gamertag to a friend's console as a convenience, as you could also lose your saved games!
hope this helps
Nov 28, 2010 | Microsoft Xbox 360 Console
XP problem
It means your roaming profile in server is missing.
please tell me do you have roaming profile in domain or not.
May 03, 2010 | Microsoft Windows XP Home Edition
Roaming profile error when I log on with my hnah\3500018 id.
how to solve Windows cannot find the local profile and is logging you on with a temporary profile. Changes you make to this profile will be lost when you log off.
Apr 15, 2010 | Profile 200SX Car Audio Amplifier
Ringtone instruction
you can easily change the ringtone. Follow these steps:
1. In Idle mode, press <Menu>--> Settings --> Phone Settings --> Phone Profiles.
2. Scroll to a profile.
3 Press <Options>--> Edit -->Voice call ringtone.
4. Select a ringtone category --> a ringtone.
5. Press <Options> --> Save profile.
Now you are done changing you ringtone. Try it!!!
Sep 15, 2009 | Samsung J700 Cellular Phone
Last year i changed my yahoo profile - is there any way to get the old profile back or to see the old profile page again?
no, am sorry once is change is totally removed am sorry. I know because I did change mine and i lost too many important pictures and documents that I was saving there. Am so sorry.
I hope this answer your question if so please rate my service thank you
Aug 28, 2009 | Yahoo Messenger
Lost instrutions for samsung j700 need to change ring tone but how?
To change your ringtone: - In Idle mode, press <Menu> -> Settings -> Phone Settings -> Phone profiles - Scroll to a profile - Press <Options> -> Edit -> Voice call ringtone - Select a ringtone category -> a ringtone - Press <Options> -> Save profile
By the way, you can download your Samsung J700 Manual here: > Link < Hope this helps.
Apr 16, 2009 | Cell Phones
Wireless configuration problem. It lost parameters I had imposted.
If you are using a MC909X, after entering the static IP address and WEP key etc. via the Wireless Configuration Editor, you can export the profile you created by going to the Manage Profiles area, tapping and holding the profile name until the menu appears, then select export, it will create a registry file in the Application folder of the device that will persist after a cold boot, and the settings will will not be lost.
Oct 30, 2008 | Symbol MC9090 Barcode Scanner
Sync doesn't sync with Calendar, then Hot Sync crashes
Try Creating a New profile from Start Control Panle > Mails > show profile > Add profile > After Adding the profile set the new profile as default
Try deleting the partnership by disconnecting the device and opening and deleting the partnership.
Plug your device back and try to sync
This should work
Sep 11, 2005 | Palm Treo 650 Handheld
MyRete WhosHere Logo
51 people viewed this question
Top MyRete Apps Experts
Marvin
Marvin
Bill Boyd
ray gallant
Are you a MyRete App Expert? Answer questions, earn points and help others
