Question about Connex Radio Communications
Increase mod. and rf output on connex 3300 hp
5 Related Answers
Ray Murphy
  • 68 Answers
SOURCE: connex 3300 hp
U mean on sideband? Frequency counter only useful on other than sideband operation. This does not mean the carrier insertion osc. is on frequency. If it needs adjustment, your voice will sound high/ low on transmit. Incoming signals will sound right after adjusting the osc.
Posted on May 25, 2008
One Wire
Dean Pitts
  • 126 Answers
SOURCE: Manual for Connex 3300 HP
The best place for anything related to cb radios and ham radios is www.cbtricks.com.
Here is a direct link to the owner's manual for a Connex 3300hp
http://www.cbtricks.com/radios/connex/cx_3300_cx_3300hp/graphics/connex_cx3300_cx3300hp_om.pdf
Dean Pitts
Rollin CBs
Posted on Aug 31, 2008
Anonymous
  • 7 Answers
SOURCE: Need to know the normal use settings for the
turn the rf gain all the way uphave your pa fm am knob on am your band knob on your desired band hi rf power band hi or low depending on wich ever u want to uss
Posted on Mar 23, 2009
JOHN BABA
  • 1274 Answers
SOURCE: Knob setting of front of radio (Connex 3300)
The best way to set it is to get you a radio check, go to channel 19 and ask someone about three to five miles away to give you a radio check, start with your modulation all the way open and go from there.....hope this was helpful...
Posted on Apr 20, 2010
Anonymous
SOURCE: Just need to know what are proper settings on my
The proper setting depend on what you are doing with the radio at the time.
Here is a link for the owner manual http://www.cbtricks.com/radios/connex/cx_3300_cx_3300hp/graphics/connex_cx3300_cx3300hp_om.pdf
Posted on Oct 19, 2010
Connex 3300 hp-blows regulator every time you hook up power cord. On/off switch can be on or off, no matter , center leg of 2sb827 shorted to ground . RF finals test good .
This is a problem that can't be diagnosed over a computer. There could be several reasons that the AM regulator is being blown. The radio needs to be serviced by a Radio Technician.
Jul 14, 2015 | Connex 3300 HPB 10 Meter Ameteur Radio
No transmit signal
Does the unit work when it is not hooked up to the linear? The obvious choice is that you have blown finals in the RF output section of the radio.
Apr 02, 2014 | Connex 3300 240-Channels Base CB Radio
Have a new connex 3300hp i can hear everybody else but nobody can hear me when i key up and talk the needle dont even move
look up the tune specs VR13 (L PWR) L32 L33 high power maybe your watts are turned down if it is brand new send it back to the place you bought it from.If the watts are turned all the way down you won't get any carrier your needle is not moving when tranmitting there is no rf power check to see if your tx light is on when depressing the mic button. you should have a rf adjustment turn it clockwise to turn the power up on the front of your radio.or the mods i gave you in the radio.
Mar 31, 2011 | Connex 3300 240-Channels Base CB Radio
My Connex 3300 the Recieve is going out I can here will close but thats it.. Antenna, Coax, SWR's are fine..... Could it be the recieveing ship in it going out or what???
Hi, my name is John. Welcome to FixYa. Turn your RF GAIN to MAX. and SQUELCH to MAX. If you need further, let me know. Thanks for choosing FixYa.....John
Nov 17, 2010 | Connex 3300 240-Channels Base CB Radio
My connex 3300 hp stopped reciving it transmits people can hear me loud and clear but I cant hear them radio was working fine then one day I turned it on and couldn't hear any thing.
Hi, my name is John. Try a external speaker, plug it in the back of radio, turn the RF GAIN to MAX. Turn the SQUELCH all the way to left, make sure the select knob is on CB, and on AM...try all this and if that's does not do it, let me know, I will post other steps here,.... hope this was very helpful....
Sep 02, 2010 | Connex 3300 240-Channels Base CB Radio
My connex 3300hp just stopped transmitting. why? it has power and i hear myself from the speaker, though no one else can hear me.
The RF final output transistor(s) is probably blown. They are not very difficult to replace if know your way around with a soldering iron.
Oct 09, 2009 | Connex 3300 240-Channels Base CB Radio
Does anyone know the pod too turn for lowering the watts on my connex it is too high and i would like to turn it back also the modulation thanks
You have to adjust the high key first so make sure you're rf power is on high, hope you have a meter set it on the 20 watt scale, key up and turn vr 13
located in back of radio infront of where you're coax connector is until it keys around 12 watts, thats where most connex 33hp should be set,now go to low power and key adjust vr 16 right net to the otherone down to about 3 watts, now you can drive a liners. Mod is Vr 2 right below them two. whistle in mic and turn to get the mod you want.
Jul 15, 2009 | Connex 3300 240-Channels Base CB Radio
Need to know the normal use settings for the Connex 3300 HP. Changed trucks and wife cleaned the radio; I believe the settings all got messed up. Thank you very much.
Mar 22, 2009 | Connex 3300 240-Channels Base CB Radio
Radio Communications Logo
576 people viewed this question
Top Connex Radio Communications Experts
Tony Raia
Marvin
Marvin
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
