2000 Ford Crown Victoria Logo
Anonymous Posted on Mar 20, 2013
Starter fuse keeps blowing
The starter fuse keeps blowing out on my 2000 crown Victoria everytime I start it. The next time I try to use my car it wont start then when I check the fuses its blown. Alternator and battery are fine...i think it might be something with a short circuit...I don't know. please help
Stewart Powell
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 11 Answers
  • Posted on Mar 20, 2013
Stewart Powell
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
11
Questions
Helped
9337
Points
24
Hi,i would say the solenoid on your starter is faulty
5 Related Answers
A
Anonymous
  • Posted on Aug 13, 2008
SOURCE: 1992 crown vic 4.6l
did you check the inertia switch?? that's what happened to mine
Anonymous
  • 38 Answers
  • Posted on May 16, 2008
SOURCE: Blows fuse wont start
More than likely its being caused by a short-circuit to ground in the wiring in your Cranking Circuit.
If it blows the fuse immediately after installing the fuse, its probably a hot-wire. If it blows it the second you try to crank it over, its probably one of the wires between your ignition and the Starter Relay.
To track down the bad wire you'll need a Wiring Schematic for the vehicle and either a Digital Volt/Ohm-Meter or Test-Light and a basic understanding of wiring which is... honestly a little hard to explain over the internet. However, that is the only course that can be taken without taking the vehicle to a qualified Dealership Technician.
Anonymous
  • Posted on Apr 01, 2009
SOURCE: i need a diagram for a 1998 ford crown vic interior fuse box
ITS FUSE #16 AND ITS a 20A FUSE
Jonah Oneal
  • 14092 Answers
  • Posted on May 10, 2009
SOURCE: 2001 crown vic keeps burning 30A PCM relay fuse
have fuel pump checked i have known a bad fuel pump shorting out causing pcm fuse to blow.
Anonymous
  • Posted on Nov 07, 2009
SOURCE: brake switch fuse keeps blowing
I Have the same problem with my 97 ford keeps blown fuse 15 amp,when I step on the brake pedal,to shift out of park it blows the fuse.can someone help me out what to look for.I replaced the switch on brake pedal that wasn't it.
My fuse keeps blowing under dash when I turn my ignition to start car 2008 Ford Crown Victoria Police
Make sure what fuse it is first. You might also wanna look at any fuses and fusible links under the hood.
2answers
1997 V8 4.6l. It turns over, but why won't it start?
Part 1 -How to Test the Starter Motor (Ford 4.6L, 5.4L)
troubleshootmyvehicle.com > Ford > 4.6L, 5.4L
Mar 2, 2011 - Page 1 of 3: How to test a BAD Starter (Ford 4.6L and 5.4L Pick Up and SUV). ... a BAD starter motor on your 4.6L or 5.4L V8 equipped car, pick up or SUV. ...and will turn over the engine; -OR-; The starter motor won't do a thing. ... Crown Victoria ... 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005.
Question: 1997 Crown Victoria Lx Cant Turn on and Cant ...
www.2carpros.com/.../question-1997-crown-victoria-lx-cant-turn-on-an...
May 26, 2014 - Ok so i put the keys in the car turn the key but seems to me it moves more ... 1997 Ford Crown Victoria ā€¢ 4.6L V8 RWD Automatic ā€¢ 99,625 miles ... Keywon't turn off accessories or turn car over and ignition cylinder turns too ...
2004 crown Victoria HEGOs fues keep blowing
I would take it to a auto store and they can check your battery circuit for free to see what the problem could be they will hook up a tester that will check the circuit out.
2000 Crown Victoria only clicks when I try to start it.
Check ground wire. It can build up rust where it bolts to frame.
If this doesn't work then have someone check starter.
1helpful
Crown vic 2000 wont crank ? battery, alternator,starter,starter relay all good ?
The problem is in the wiring harness,yes the battery and starter is good, the harness you repaired is the PRNDL. for the starter to start it need a path when the vehicle is Park or Nuetral,there the path is closed some how by Park and Nuetral the path is open.Thats why there is a no start.when in park or nuetral the path is closed.
'99 Ford Crown Vic LX: #12 30A Maxi fuse blows seconds after starting or ignition turned on.
i had this problem with my 1999 jeep grand cherokee laredo with the brake lights it kept popping fuses right after the ignition was turned on try putting a higher amp fuse in place of the old one that keeps blowing then check for shorts to the starter and check grounds and wires and also the transmission issue check the fluid and then if the fluid is fine change the transmission filter the filter may have not gotten replaced when the transmission was rebuilt and may be clogged or dirty
AC FUSE KEEPS BLOWING ON 1998 FORD CROWN VICTORIA
with out knowing what you have for tools unplug different parts of the system and try another fuse like the compressor clutch the pressure switches and plug them back in one at a time til the fuse blows if you have a ohm meter check to see if any part is shorted to ground
AC fuse keeps blowing on my 1998 ford crown victoria
The reason a fuse blowing may be because of a short circuit. And you should check any wire connectors that plug into the pc board.
___________________
fiat km tool software
1helpful
I have a 2000 crown victoria and whn i turn the key it does everything but fire it cranks but still wont start chnaged the starter,altanator, just not sure whats next
The next thing I would check is to make sure the fuel pump inertia switch isn't tripped. It's located in the trunk, on the side. You should see a little hole. Looking inside, you'll see a button that faces up. Push down on it. If it clicks down, chances are, you found your problem. This switch is used as a fuel pump cutoff in the event of a collision, so fuel doesn't feed a potential engine fire.
I hope this helps! :)
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
