Computer powers on but nothing shows on monitor, monitor is on
SOURCE: Get NO SIGNAL on Acer M1640~Monitor is Fine~Is CPU
Try removing the system memory and clean the brass contacts and the slots it goes into, then reseat the memory and try to boot again, the memory looks like this >>>>>>>
Good luck
SOURCE: How can I find a replacement power supply for my
you can buy a power supply in ebay or amazon.. remember find the spaficication of the power supply and you can put a generic.. its more cheaper... with the same spec of your machine
http://shop.ebay.com/i.html?_nkw=Desktop+power+supply&_sacat=0&_trksid=p3286.m270.l1313&_odkw=Acer+X1200&_osacat=0
pls click if my solution was helpful
Testimonial: "thanks will check it out"
SOURCE: Acer Aspire M1640 2GB Display Problems
Does your comp beeps when you power it on. if no then your motherboard got problem, remove your ram and reinsert it even it doesnt come then check the chipset big one on the board if it is getting very hot the u need to repair your boar. if you r in bangalore call 9972888885
SOURCE: I have an Acer Aspire x1200, when I press the
their r a few possible solutions the first thing i would chk is which fan is on , processor or power supply, or both. if no processor fan, processor/motherboard may b burnt or . chk for loose connections.. if your screen image is black u may have fried the board, if blue then it would b a hardware issue..
