Question about Tomtom ONE GPS Receiver
Not enough space to update - Tomtom ONE GPS Receiver
Posted by soe_myint13 on
LP
  • Tomtom Master
  • 514 Answers
You'll want to (first) backup your navigation software and map data(base) onto your PC (using HOME or Windows Copy). Then, remove some of the "not used" data from the GPS ... e.g. voices, symbols (e.g. cars), etc. After that, you may wish to do a DeFragmentation on your GPS storage device ... using the usual Windows (defrag) utility ... e.g. from File-Properties-Tools-Defrag.
Then try connecting the GPS (using HOME) to your PC again, and see if there's enough space for updates.
Posted on Dec 28, 2013
My Apple iPad 2 won't update. It's running iOS 9.
It may be too full. Check how much free space you have. Try to have approximately 3GB free. Delete things that are easy to replace like apps, or music you can download again.
Oct 04, 2015 | Apple iPad 2
I want to update my iPhone 5s to newest iOS 8.
Connect to your PC and open iTunes. You can update from there!
Nov 14, 2014 | Cell Phones
Why can't I update iOS to my iPod ,second generation ????
Usually the problem is there is not enough space to take the update. Best to clean up the unit by deleting stuff you no longer need. When you try to update, you should be getting a message about not enough storage.
Oct 07, 2014 | Audio Players & Recorders
Status code 4174-0000-3080-0504-8007-000D
This is very simple: you seem to not have enough hard drive space for a system update that your console is trying to install.
Error 8007 0070 occurs when you install an update or buy content on...
(I've pasted some bullet points for you)
" Error 8007-0070 occurs when you install an update or buy content on Xbox 360
Problem
You may see the following error code and message when you try to update your Xbox 360 console or purchase content:
xxxx-xxxx-xxxx-xxxx-8007-0070
Note
The "x" characters in the error code vary.
This may mean that there's not enough space on your storage device (mostly likely the Xbox 360 hard disk) to install the update or the content.
Solution
A console update or content download may require significant hard disk space. If you don't have enough free space, you need to move or delete some items."
You can probably get around this by using a 32gb USB thumb drive and moving some of your content that's hogging up your console's space onto that thumb drive temporarily.
Heres the Xbox.com info to get you started about moving and deleting hdd space--which also has info about using a USB thumb drive, too. Copy move or delete Xbox saved games profiles and avatar items
Jul 21, 2014 | Microsoft Xbox 360 Console
Xbox360 update download failing
This usually happens when the Xbox does not have enough space to save the update to in order to install it. Make sure you clear out enough space so you are able to properly install the update.
Here is a list of other errors that can happen to system updates.
http://support.xbox.com/en-US/xbox-360/system/software-update-errors
Contact back with the code you get if you cannot fix it using Microsoft's tips and I will try to help.
Apr 08, 2014 | Microsoft Xbox 360 Console
Ive tried to install new map but says i dont have enough space
Make a backup first on your hard drive not tomtom home of all the files on the GPS
then log on to tomtom home for updates
there will be a option to delete some of the things you do not need
many Foreign voices
then there will be enough space for updates
Dec 08, 2010 | Tomtom One XL GPS Receiver
Not enough space? sansa m240
try formatting the device..that must solve the problem...if it doesnt,use sansa updater to update its firmware
Sep 07, 2009 | SanDisk Sansa m240 MP3 Player
221 GB Free on MyBook - Error states not enough space for backup
It may be due to the file system.  If formated as FAT32 files larger than 4gb may not transfer.  Try reformatting as NTFS to fix the problem.
Sep 21, 2008 | Western Digital 250GB MyBook External USB...
Is the drive formatted as FAT32?
If so, and your backup is more than 4GB, it will not be able to write the file to the drive.
Open a Command Prompt (Start | Run | CMD) and at the prompt type:
CONVERT V: /FS:NTFS /X
Where V: is the drive letter of your My Book.
That will convert it to NTFS and it will be able to handle files larger than 4GB.
Apr 28, 2008 | Western Digital My Book Essential Edition...
Tomtom ONE GPS Receiver Logo
142 people viewed this question
Top Tomtom GPS Experts
k24674
Marvin
Marvin
Ekse
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
