SOURCE: Blank/Black Screen Asus PC 4G
When you first turn on the computer, start tapping the F8 key to bring up the safe mode screen. You have a very short window in which to press the F8 key before XP loads, so it is possible to miss it. If this happens, just restart it and try it again. Once you are on the safe mode screen, select the enable VGA mode. This will boot your computer to a default 640 x 480 resolution so you can change it back to normal.
Thanks and please don't forget to give this solution a fixya rating.
SOURCE: My Acer laptop will not load.
Try this, Acer told me to do this and it worked.
The
other way before Vista starts up is to tap ALT + F10 (at the same time
repeatedly) when the computer is first switched on.. The window of
opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then
it indicates that you have tapped the ALT + F10 correctly, and all you
now need to do is press “Enter” and the Recovery program should load on
your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
SOURCE: asus eee pc 900 /windows/system32/config/system
2 problems, your using a netbook that doesnt have an optical drive (cd/dvd) and you need a windows cd.
I dont think there is anything you can do until you call your retailer and request a copy of windows cd.
After that you can do a windows repair. Use the link below to see you options for accessing the cd once you have it.
http://www.itworld.com/windows/68069/three-ways-install-windows-7-netbook
SOURCE: ASSUS eee pc 1ooo H doesnt start from time to time !
do you have it set to hibernate check that setting ...the whole on the bottom is the reset switch for the machine
SOURCE: My asus Eee pc 4g 701 will not connect wireless
yes! when it comes to wireless networking just make sure that your connection setting are correct just match the settings from your other laptops and do the same to the one you have probles if the persist just do a diognistic check for problems if that doesnt works just hit me back on my link ok!
