Question about Samsung SCX-4216F All-In-One Laser Printer
I have a Samsung SCX4216f Scan Print Copy Fax and I seem to be missing the TWAIN?? I can't get it to scan.
Posted by Kareene on
sylviaivie
  • 1,564 Answers
Check your computer for the driver, reinstall scanner/copier if necessary.
Posted on Mar 20, 2013
5 Related Answers
Anonymous
  • 161 Answers
SOURCE: Samsung CLX-3160FN "scanner locked"
Every Samsung multifunctional device has a scanner lock underneath the glass. This is to prevent scanner damage during shipment. Th user's manual in the CD and the unpacking sheet clearly illustrate where this lock is. If you open the top lid and look to the lower left corner of the glass, you will see a small lock-open/lock-closed symbol. Underneath that symbol you will find the lock. I'm including a small visual reference of a similar model. Just remember to turn off and on the unit after the lock is removed.
Posted on Oct 02, 2007
Anonymous
SOURCE: Samsung "scanner locked"
I went through the same thing! It drove me nuts, and I even calls CS, which is great by the way. The sweet girl on the other line couldn't figure it out, but I finally Googled it.
In the opening where the printed pages come out, if you put your hand in there, on the top left is a lever.
This is the scanner lock. Once you flip the lever and hit the stop/clear button, it should be all better. At least that is what worked for me!
Posted on Nov 15, 2008
SOURCE: Samsung SCX-4720F reads "SCANNER LOCKED" and won't copy or scan.
the lock is underneath the scanner where the printed paper gets delivered. when you reach in to get a printout you more than likley have pushed it into the lock position.
Posted on Jan 06, 2009
Anonymous
  • 58 Answers
SOURCE: My Samsung CLX-6200 Network MFP printer prints but does not scan
Hmm Tricky,
You could try temporaily disabling the windows firewall, and any anti-virus firewalls to see if they are blocking communications to the scanner.
(Please rate my answer thanks :)
Posted on Jun 23, 2009
Anonymous
  • 6 Answers
SOURCE: The OEMCFG.dll on Samsung needed
GO TO SAMSUNG/SUPPORT.COM
TYPE IN YOUR MODEL# AND DOWNLOAD THE DRIVERS YOU NEED.
Posted on Jul 15, 2009
Dear Sirs/Madams, I have a Muratec MFX-1930 network multimachine (printer,scanner,copier,fax). Everything is working fine i can print, fax, copy and scan. My problem is the scanner scans to internal...
Unless your machine is connected via ethernet cable.( NOT USB.!!) you will not be able to scan directly to a Network folder.
Anotherwords..you can scan to a Network folder if its an RJ45 cable but NOT if your using USB.
If you are using ethernet the machine should have come with the appropriate software...if you have lost it you can get it at www.muratec.com .
**If you are using USB...installing the Network software will NOT make it scan to folder.
Apr 01, 2011 | Muratec Copier
I want a driver software to scan from this printer scx4216f samsung
Driver software for the SCX4216F Samsung printer can be found at the following
website http://driverscollection.com/?H=SCX-4216F&By=Samsung
Follow all of the instructions on the site for proper downloading of the software.
Jan 21, 2011 | Computers & Internet
Scan from printer through router to pc?
You will need to use the TWAIN software for the printer. From the computer you will be running the scan options thru the TWAIN software. Then the scan files will be pulled from the printer back to the computer. Running scan options directly from the printer will give you the option to print the scan files or send them to a memory card if your printer has a slot for one. If the scanning software is not installed on your computer then you will need to download it from the manufacturer's website.
Sep 22, 2009 | Dell 1815dn All-In-One Laser Printer
Requiring scanner software for samsung SCX-4216F printer
Dear Sir,
I have Samsung SCX-4216 printer. Printing, Xerox & Fax working is OK, but scan facility is not working because i missed the original software. please give me  a solution for get the original software or scan drivers.
With Regards
Mohan
Dec 27, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Will print but not copy or scan
sir,
click this link to solve your problem
thanks
good luck
Nov 26, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Hp scanner 3030
i have a hp 3030 all in one is there.. printer, xerox, fax is working properly but scan is not working .. kindly solv this problems..
Aug 31, 2008 | HP LaserJet 3030 All-In-One Printer
ADF not working for TWAIN APIs
I need a little more description. Does the ADF handles the first page, or no page at all? Keep in mind that Samsung designs its own scanning application (SmartThru). Also check that the connection (parallel or USB) is correctly configured on your app.
Dec 20, 2006 | Samsung SCX-5115 Fax Machines
Samsung SCX-4216F All-In-One Laser Printer Logo
212 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
