Kenmore 110.68002010 Dryer door switch replace
yes,unplug it,get a putty knife and slide it under the top control panel on each corner,there's two clips one on each side,then when you free up the control panel there's 3 1/4 inch screws,remove them and slide the top panel forwards,there's 2 phillips screws that hold the door switch in place,get a thin tip screw driver,slide it into the plastic wire connector to separate the switch from the harness.i'm pretty sure this is how you get the top off.go here,open top and console and you'll see the clips on the top panel,then go to cabinet parts and the door switch is the common one it's number 41 on the look up part WP3406107 hope this helps you out,
https://www.searspartsdirect.com/model-number/11068002010/0582/0151200.html?searchType=modelSearch&q=110.68002010&searchTerm=110.68002010
