Is the frequency band allowed in India? Whether licensing is reqd or not?
SOURCE: Motorola T5728 walkie talkie freq mismatch
Unfortunately the T5728 is not compatible with the US FRS (family radio service) frequencies. The T5728 operates between 409-410MHz. The FRS radios operate between 460-470 MHz. FRS frequencies are license-free frequencies for use in the US, as regulated by the FCC. Other countries have differing rules and thus their frequencies assigned to family usage differ.
SOURCE: communication not good &battery cannot charge
If your area is big or has a lot of concrete, then you will need more then just a few cheap radios from thailand, Given range info from broshure is always meant above flat area - not inside building
SOURCE: Is kenwood walkie talkie and motorola walkie
If you are talking about FRS radios, the answer would be yes. If you are talking about business radios, it depends on how they were programmed. Business radios have many frequencies available.
SOURCE: I need to know the
Here's a link to the instruction sheet for the FV300. It lists the frequencies for all 22 channels.
http://www.banoggle.com/products/motorola/manuals/FV300-manual.pdf
SOURCE: My sons are hunting near
Channel 4 should be 462.6375 MHz, and code 4 should be 77.0 MHz.
Best regards.
