Just bought this tv today used for $175 It has a large purple area on the left center of the screen. Non of the audio components work but The hdmi ports ports work fine.
SOURCE: JVC HD TV MODEL HD55G
kinda like a water mark... i fixed a few of these and to me it sounds like something in the optics. eather on the mirror or in the engine... send it to a shop while its still under warrenty. they probally will replace the engine for you under warrenty.
SOURCE: HD-58S998 This TV gets very
Try checking the manual for this one for the step by step way top set it up http://resources.jvc.com/Resources/00/00/90/YA501ien.pdf
Hope that helps...........
SOURCE: JVC HD-70FH96 both HDMI problems
Have you been using a flashlight behind the TV. These TV's have a sensor that shuts off the unit when the rear cover is removed (by sensing light). You may have tripped this. I think you can fix this in the service menu somehow but I can't remember.
SOURCE: My tv screen is green
there is a code to reset the HDMI video, i think it is--hit Display on the remote, then sleep timer and video statice at the same time, then the number 2, then turn the tv off, after it shuts down all the way, turn it back on, should take care of it
SOURCE: Color fine with rca jacks but when using hdmi/component its not
There may be a number of problems that are causing your HD issues. They may exist in your TV, or in the box you use to tune your channels. Contact your cable or satellite provider and ask them to change out your box. If the condition still surfaces, then you need to have your TV checked. The component and HDMI jacks are both connected to the same electronics. This is why they are exhibiting the same problem.
