Question about Pioneer DEH-P9800BT - In-Dash CD/MP3/WMA Receiver With Bluetooth Wir
My Pioneer DEH-P9800 BT faceplate won't close
Have had this unit for about 3 years, and now the faceplate won't close all the way. It only goes about half way and then stops. The rest I'd the unit works fine still, but I'm worried about the faceplate in the sun all day because it isn't in the dash all the way.
  • 760 Answers
The clip that locks the plate into place probably broke.
Posted on Mar 21, 2013
  • demearthur46
    demearthur46 Apr 16, 2013
    so what should i do to fix tht prolem?
2 Suggested Answers
6ya staff
SOURCE:
freemind
  • 17 Answers
SOURCE: Hi, I have owned a
The ribbon cable should be replaced. It is a common problem.
Posted on Sep 18, 2009
Faceplate won't open all the way
Sometimes the mechanism is misplaced, just disassemble that mechanism and turn on radio without the secondary plate and wait until the motor to get to the final position when it turns off again, reassemble.
Oct 06, 2012 | Pioneer Premier DEH-P960MP CD Player
Fridgidare washer front load won't spin & there's water in the tub. It's about 10 years old
If it's that old, you're better off buying a new unit. You'll spend about half the cost of a new one fixing it.
Jun 11, 2012 | Washing Machines
Electric window wont stay up
It sounds like you may have a bad switch. It could possibly be removed, cleaned and reassembled/ reinstalled and work fine, otherwise it will have to be replaced.
Mar 13, 2017 | 2003 Saab 9-3
My Keurig is stuck. The top of the handle won't go in :( it won't close. Stuck open.
Remove the Kcup basket and clean. Rest and strat over. Pull down and reset handle.
Jan 21, 2012 | Keurig Elite B40 Coffee Maker
It is three and a half years old and ices up even at warm temps.
The problem you're having is generally caused by the air intake filter needing to be removed and cleaned and/or the cooling coils need to be cleaned.
I assume you already know how to remove and clean the filter, since you've had the unit for 3 1/2 years, so I won't bore you by addressing that.
The coils can be cleaned with warm water and a mild dish washing detergent using a sponge or rag. Once they have been wiped down, rinsed and dried, apply a light coating of WD40 to the coils.
Hope this helped you & thanks for choosing FixYa.
Sep 19, 2011 | Kenmore 54701 Dehumidifier
It won't let me on i'm on auto sign in and usually i'm straight on now it goes half way and stops why?
Flirtomatic usually works by using cookies. So When you set the browser to clean and close, it also deletes cookies. You can set it to allow cookies from flirtomatic. 1. Go to Settings. 2. Click Safari 3. Click Accept Cookies - Always
If this helpful, please give a testimonial and vote by pressing button thumbs up.
Sincerely, Thiyaga
Aug 23, 2011 | Flirtomatic
Kenwood KRC 535 - Faceplate stops halfway when turning off unit. When unit on it will play music, but nothing lights up so you don't know what you're listening to. Also cannot change station. ...
There is a fine ribbon cable that links both the main unit and the face plate. Due to the constant movement of opening and closing some of the conductive tracks develop cracks. That is the reason why when it closes half way it looses contact and the motor stops turning. The display illumination track must have completely broken.
You will need professional help to replace it because its a little complicated to access this ribbon cable.Will cost you about 15$ plus labor.
Jul 14, 2011 | Kenwood KRC 535 Cassette Player
Xbox 360 Console: My xbox 360 will keep opening its tray and it won'...
The very first thing, I would suggest you is to check the CD cover, as sometimes labels on CDs prevent tray to close.
If that does not work then do the following.
Remove disc from the tray, make sure the faceplate is on correctly.
The faceplate is the plastic piece on the front of your console.
• Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
• If you find that the faceplate is the problem, please contact Xbox customer support to order a replacement faceplate.
If this does not resolve your issue, please try step 3 and other steps from following link.
http://support.xbox.com/support/en/us/xbox360/kb.aspx?ID=907590&lcid=1033&category=hardware
If you wish you can also use following link of interactive troubleshooting wizard, which will assist you to narrow down on the issue.
http://support.xbox.com/support/en/us/Solutions/wizardhost.aspx?wizardid=xdds
This solution is absolutely free. If your issue is still not resolved, please feel free to ask.
Please rate and give your feedback.
May 03, 2010 | Video Game Consoles & Games
Faceplate stays half opened, half closed will on not turn
I have the exact same problem. I called the Kenwood tech line and the tech reported that the ribbon cable is probably broke. It is the flex cable between the head unit and the rotating face plate. He said it's not an expensive fix but we would need to mail it to a service center if you're like me and not near one. I just replaced mine with a new unit. It was about time anyways.
Nov 21, 2008 | Kenwood KRC-X858 Cassette Player
Pioneer DEH-P9800BT - In-Dash CD/MP3/WMA Receiver With Bluetooth Wir Logo
384 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
ThaMp3Doctor
ThaMp3Doctor
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
