Question about DISH Network ViP 211 DTV Receiver
Switch installation failure
Receive a switch installation error while installing receiver
Posted by southbizhemp on
dish
  • Official Brand Answer
  • 263 Answers
I can understand why that would be frustrating, southbizhemp. I hope this has been resolved, but if not I would be happy to help!
Is there a number on the upper right corner of the message? Is this a replacement receiver, or a brand new one. Are all the cables tightened?
Tommy Faust
DISH Social Media Representative
Posted on Mar 26, 2013
I'm using d-link dwl-3200 ap ( three) Received Frame FCS Error Counts indicate a problem? ___________________________________________ WLAN 802.11G Traffic Statistics Throughput Transmit...
Transmitted Error Count 4734440
Ack Rcv failure Count 15269951
  • As per the above there are error on Transmitting the packet and also for receiving the acknowledge packet.
  • Please check whether any disturbance in the link
  • Each PPP packet has a checksum attached to ensure that the data being received is the data being sent. If the FCS of an incoming packet is incorrect, the packet is dropped and the HDLC FCS count is increased.
  • Another reason for seeing too many FCS errors may be that the remote end has stopped talking PPP.
Feb 27, 2011 | D-Link AirPremier DWL-3200AP 802.11g/b...
I have prloblem with nsis error
The installer has failed a self-check. This means that for some actions, the installer file has been altered from its original form. If the install were to continue, the software install would not be complete and will be broken. To prevent further problems, the installer refused to continue.
If you are receiving this problem from an installer located on a disc or other media besides the Internet, then the problem may be due to a hardware failure or more likely the physical media being damaged. Try reading files from other parts of the media. If you are receiving read errors with other files on the disc, then the problem is likely due to damaged media. You will need to contact the source of the physical media for a replacement.
As a last resort, the installer can be executed even though it's corrupted. To bypass the corruption test, pass /NCRC on the command line. To do so, go to Start->Run, type cmd and hit Enter. A black console window should open. Drag the installer into the window, hitSpace and type /NCRC. Hit Enter again and the installer should start. This is not recommended!
NSIS Installer/Uninstaller will raise this error whenever you will launch the installer/uninstaller from an forbidden location (such as C:\, C:\Windows, C:\Program Files, etc).
Dec 27, 2010 | HP Computers & Internet
I have a epson sx215 and have a error code e-01 can you help
To Recover from the dreaded E-01 ERROR simply follow my RS232 loading instructions But REPEAT step 4 and 5 Twice BEFORE moving on to step 6
NOTE
ALWAYS Unplug your receiver BEFORE disconnecting Or Connecting your Coax cable Or RCA cables !! FAILURE to do so WILL damage your receiver !
1) Download and unzip both the ( COOLSAT7000_FAC_V0111 ) and NorW latest release
2) Connect your receiver to your computer using your RS232 cable.
3) Open your Coolsat 7000 Loader click the file button and load your Coolsat_7000_Fac_Vo111 into your loader
4) Timing is everything on this step ! Put your mouse over the download button and as soon as you turn the Back power switch on your receiver ON click the download button
If your to slow it will NOT load and you must Repeat this step !
5)When your receiver reboots itself Or you see this ---- turn off the back switch and reconnect it to your TV then click Menu on your remote and then go to Installation screen and select SYSTEM RECOVERY and click YES to (System restore to Factory Default) when the factory reset is finished set the Language of choice and then set your time zone. After setting the time zone the receiver will ask if you want to Auto detect your satellites and switch settings. Say NO at this time !
6)Now Repeat the First 5 steps to load the Latest Coolsat7000_NorW-bin !
BUT this time say YES to Auto Detect and it will auto set your LNB type and switch settings and then scan All the satellites your pointed at !
NOTE
ALWAYS Unplug your receiver BEFORE disconnecting Or Connecting your Coax cable Or RCA cables !! FAILURE to do so WILL damage your receiver ! user_offline.gif digg.gifdelicious.giftechnorati.giftwitter.pngreddit.gif quote.gif
Nov 15, 2010 | Epson Stylus CX6000 All-In-One InkJet...
I receive Err 99, it says to re install battery or
It is due to some kind of electrical contact failure.
For more details and common causes of Err 99 read the following article:
http://www.lensrentals.com/news/2008.12.31/canon-err99
May 14, 2010 | Canon EOS 40D Digital Camera
When the radio is switched on, the speakers crackle then after a while the display shows failure and then the sound is clear
Check all speakers are still working you will find might find one isnt.
The message Failure means a speaker or amp incorrectly installed.
Mar 14, 2010 | Sony MEX-BT2500 CD Player
How do I correct error code 04 when trying to playback DVR event?
Follow this article to fix the issue.100% Guaranteed
http://social.technet.microsoft.com/forums/en-US/itprovistahardware/thread/bd9763de-6141-45ea-990b-70c207fe3fb6
Feb 26, 2009 | DISH Network DVR-625 DTV Receiver /...
Installation failure.Error 1311: Source not found.Verify file exi
http://support.microsoft.com/default.aspx/kb/325076
i hope this helps basicly it sais you might not have enough rights.
there is also a solution in there.
i couldnt find anything else on the error you specified.
Feb 07, 2009 | Microsoft Office Home and Student 2007...
DISH Network ViP 211 DTV Receiver Logo
Top DISH Network Televison & Video Experts
matt martin
matt martin
Sheldon Dedek
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
