Has been sitting for many years
SOURCE: engine starts but won't continue
let it warm up with choke closed manually after it starts to stall with choke closed open it and dont let it stall u can learn to play with the choke a little to get it to run right GOOD LUCK!
SOURCE: EB5000 been sitting 6 months,
Hi and welcome to FixYa, I am Kelly
If the generator has sat for some time the fuel in the float bowl will turn into a varnish like substance (shellac). The residual fuel in the carb will have to be removed. You do this by removing the fuel solenoid (or bowl nut) which ever one youhave that secures the float bowl to the carb. Then take a screw driver and remove the main fuel orifice and remove the debris from the main fuel orifice. Clean the orifice with carb cleaner. DO NOT push anything into the hole! Also spray the brass tube that the main fuel jet screws into with carb cleaner. You should see carb cleaner being sprayed into the throat of the carb.
While the fuel float bowl is removed get a spray can lid and hold it under the carb float. Turn on the fuel selector and the fuel should completely fill the spray can lid in 8 - 10 seconds. If you do not have this amount of fuel flow you need to remove the main fuel line from the carb and re-check fuel flow. If the flow is good here then use carb cleaner in the float needle area to force any debris back out the fuel manufold connection that is now open because you removed the fuel line. If you still do not have fuel flow then check for debris in the fuel tank exit port, the fuel filter, the sediment bowl under the fuel shut off assembly.
Once again with the spray can lid under the float you should have fuel flow anytime the fuel selector is on and the float level is down. It should shut off fuel just as it reaches level. Any other result and the float and float needle will have to be removed, cleaned and inspected for debris.
Make sure to re-install the main fuel orifice in the treaded area that secures the float bowl in place and.re-connect the main fuel line to the fuel manifold / carb fuel inlet connection
If the engine has a fuel solenoid hook it up and and see of it is working as you turn the key / engine switch on and off before you reinstall the float bowl. You make have to hold the case of the solenoid against the engine to make a ground AWAY from any residual fuel for testing. I.e. don't burn up your generator.
Re-install the fuel float bowl and test the engine. It should now work just fine.
The above steps are successful most of the time on generatosr that have sat idle for an extended period. I have been working on generators large and small for over 40 years.
Thanks for choosing FixYa,
Kelly
SOURCE: Honda gcv160 starts with starting fluid in carb but won't stay running
It sounds like a clogged carb. It needs to be disassembled and remove the main jet and nozzle and clean them making sure the small holes are open and free of any debris.
Testimonial: "I believe in asking for help when I need it!!"
