I am re building a 33 ft. sailboat and have never used an inverter, except for the cheap can.tire ones that i only use to grind my coffee!!!!
SOURCE: Freedom 20 Inverter / Charger
same happened to me on fleetwoo rv. the switch on the control panel was bad. put a new remote switch on works fine. hope i helped. if the remote switch port on the inverter has no wire going to it the remote might fix it.bypass the main circuit board. buxtonman`~`
SOURCE: Heart Interface link 1000 Manual??
Check the manufacturer web site:
Product Page:
http://www.xantrex.com/web/id/98/p/docs/pt/7/product.asp
User Guide:
http://www.xantrex.com/web/id/423/docserve.aspx
SOURCE: I have a Heart Interface Freedom 20
The fan can be replaced. It is very similar to some of the PC cooling fans. I've got the same problem (again) and will be replacing it soon. I will give you the fan specs once I remove my fan ( I think it is 4" 120VAC - will let you know when I repair mine).
SOURCE: Xantrex Freedom 458 Combi inverter/charger 2000 watt
OK my 2000 Discovery does the same thing. Try and hit the inverter charger with your fist 3-4 times, then listen and see if the charger fan starts up. I will be bringing my inverter to Portland this week to have the tech look at it. The other thing is it could be the transfer switch. Will let you know.
SOURCE: Where can I find parts for my Freedom 20
Contact Tekris Power Electronics
They are in NJ. Ph 732 938 4996
They know the Freedom units very well, I send all of my dead ones there. Good luck
