Question about HP Pavilion Computers & Internet
ERROR CODE 0xc0000185 - Pavilion HP Computers & Internet
Posted by ROB LOWERY on
Ivan Pajic
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 42 Answers
The 0xc0000185 error simply means that the computer can't communicate with the CD drive. It could be due to a faulty CD drive or media, a bad connection, faulty interface, bad memory, power supply etc. You will need to isolate the problem further, why couldn't you boot normally? check the BIOS settings again and try clearing the CMOS memory correctly as described in the manual (just removing the battery may not be good enough).
Posted on Mar 19, 2013
Mia Talyor
    Habit-Forming:
    Scholar:
  • HP Expert
  • 46 Answers
In this section, you will get the solutions to resolve the Toshiba error code 0xc0000185. To solve this issue on your own you can follow these steps given down below:
Repair Your Toshiba Computer
Scan Connected Hardware
Install Windows Operating System From Scratch
Posted on Jul 02, 2019
Mike walsan
    Sergeant:
  • 161 Answers
Are you one of the Windows 10 users who ran into error code 0xc0000185 while using your device ? Usually this error message appears after a reboot.
If you carefully follow the instructions listed below, you will be able to windows fix error 0xc0000185 on Windows 10 in just a couple of minutes of your time.
The error code 0xc0000185 usually comes along side the message: The boot configuration data for your PC is missing or contains errors. Unfortunately, if you unplug the USB devices from your Windows 10 machine and reboot your operating system you will still keep getting this error code.
How To Fix Error Code 0xc0000185 In Windows 10
  1. Repair your computer using the Windows 10 Installation MediaRebuild Boot Configuration DataRun System RestoreDisconnect all peripheralsRun Disk CleanupCheck your hard driveRemove recently installed softwareRun the BSOD troubleshooter
1. Repair Your Computer Using The Windows 10 Installation Media
  1. Power up your device.
  2. After your operating system started normally, please insert the Windows 10 Installation Media into the CD or DVD ROM.
  3. Reboot your operating system with your Installation Media inside the device.
  4. Now you should get to a black screen that says: ""Press any key to boot from CD or DVD" in which case you will need to press just any button on the keyboard to boot from your Installation Media.
  5. When you get to the next screen, you will need to set the correct time and keyboard type.
  6. Now select the "Repair your computer" button located in the lower left side of the screen.
  7. You should now have on your screen the "Choose an Option" window.
  8. In this window, select the "Troubleshoot" feature.
  9. Now, from the Troubleshoot menu, select the "Advanced Options" feature.
  10. Now in the "Advanced Options" window, selct the "Automatic Repair" feature.
  11. In this next window, select the operating system you are using.
  12. Windows 10 should start the scanning process and repair any errors that may be causing your system to display error code 0xc0000185.
  13. When the process has finished, take out the Windows 10 installation media disk and reboot your device normally.
  14. Check to see if the error code 0xc0000185 still appears in your system.
- ALSO READ: How to fix second hard drive stops Windows 10 boot
2. Rebuild Boot Configuration Data
  1. Insert again your Windows 10 Installation Media disk and reboot your operating system.
  2. When the device starts, you will be asked to press any key to boot from the CD or DVD.
  3. Select again the correct time and keyboard type as you did in the first method.
  4. Select the "Repair your computer" button situated in the lower side of the screen.
  5. In the "Choose an option" window , select the "Troubleshoot" option.
  6. Now, from the "Troubleshoot" menu, select the "Advanced options" feature.
  7. Select Command Prompt to launch the tool.
  8. Type BOOTREC /FIXMBR in the Command Prompt window.
  9. Press the Enter button on the keyboard.
  10. Type BOOTREC /FIXBOOT > hit Enter to launch the command.
  11. Now, type the following command: BOOTREC /REBUILDBCD and hit Enter again.
  12. When the process has finished take out the Windows 10 Installation Media from the CD or DVD ROM.
  13. Reboot your computer and check again if you still get the same error message.
3. Run System Restore
Note: It is recommended to make a backup copy of your important files and folders before you go through with the steps below.
  1. Insert your Windows 10 Installation Media once more into the device.
  2. Reboot your operating system.
  3. When the device starts, you will be asked to press and key to boot from the installation media and at that point do press any key on the keyboard.
  4. In the window that appears, select again the correct time and keyboard type.
  5. Go to "Repair your Computer" > select "Troubleshoot".
  6. In the Troubleshoot window, select "Advanced options"
  7. Click on the "System Restore" button.
  8. After you successfully completed the System Restore process, reboot your operating system normally and check if you still get the error code 0xc0000185.
- ALSO READ: FIX: Antivirus blocking System Restore in Windows 10
4. Disconnect All Peripherals
Faulty peripherals may trigger this annoying error code. Unplug absolutely all the devices connected to your computer, including your mouse and keyboard if your machine's configuration allows you to.
Now, boot up your device and check if the issue persists. If your computer boots normally, this means that one of your peripherals failed to work properly and you need to replace it.
In order to identify the culprit, connect your peripherals one by one and test if any issues occur.
5. Run Disk Cleanup
Your computer regularly stores temporary files and folders as you browse the Internet. These unnecessary files may trigger various issues, including error 0xc0000185.
We recommend Reimage for various PC problems
  • repair common errors
  • protection against file loss
  • malware aftermath
  • fix corrupted files
  • replace missing files
  • hardware failures
  • performance optimization
Find and fix Windows errors automatically
? FIX IT NOW
You can quickly clean these junk files by using Disk Cleanup. Here's how to use Disk Cleanup on Windows 10:
  1. Go to Start > type Disk Cleanup > launch the tool
  2. Select the disk that you want to clean > the tool will them tell you how much space you can free up
  3. Hit OK and wait until the process completes.
6. Check Your Hard Drive
Speaking of faulty hardware, it is worth mentioning that your hard drive may also trigger error 0xc0000185. You can check your PC health by installing one of the software listed in this guide.
If you still can't get rid of this error code, try taking your computer to a professional. If your hard drive is faulty, you may need to replace it.
7. Remove Recently Installed Software
In rare cases, this issue can be triggered by incompatible apps and programs. So, if error 0xc0000185 occured right after you installed new software on your machine, uninstall the respective software and check if the issue persists.
8. Run The BSOD Troubleshooter
Another quick way to fix this Windows 10 error code 0xc0000185 is to run the built-in BSOD troubleshooter. To do this, go to Settings > Update & Security > Troubleshoot > go to Find and fix other problems > select and launch the BSOD troubleshooter.
And this is how you can fix your error code 0xc0000185 on Windows 10. If you have additional questions related to this subject, drop us a line in the comments below. I or my colleagues will help you with additional troubleshooting steps.
Call On Our Technical Support Phone Number for Fix Windows 10 error code 0xc0000185 by Errorcode Expert
USA +1 (800) 848-5295 Right Now to Get Instant Help
Posted on Feb 13, 2019
Ashar ali
    New Friend:
    Problem Solver:
  • 8 Answers
I am getting some error 0xc0000185 and cant access Cricinfo can anyone please help me Ball by Ball Live Cricket Score Cricinfo Schedule Highlights
Posted on Jan 18, 2014
Maha Noor
I was facing same problem on my HP ENVY dv6 i7 machine which created while I was surfing cricket scores which leads to my data loss.
I used external USB drive to re-install my windows 8 on the machine. I'm not feeling good with dv6 series by HP.
Posted on Aug 18, 2013
Hi I have a Asus notbook F550L it crashed on me this morning and a blue screen came up with error 0xc0000185 I dont have a windos disk or recovery I am running windows 10 on it
Error 0XC0000185 is caused by a boot error, probably faulty hdd.
The licence on win10 is stored with the motherboard so if you fit a new hdd, win10 can be recovered using your email and passwords at microsoft.
http://www.microsoft.com/windows10/recovery
Feb 01, 2017 | ASUS Computers & Internet
Windows & will not start. Status 0xc0000185
Your laptop cannot communicate with the hdd.
Try the link.
Windows 8 Error Code 0xc0000185
Apr 25, 2016 | Computers & Internet
0xc000185 error
How to fix The Specific Code Is 0xc0000185 errors? There are several methods of fixing The Specific Code Is 0xc0000185 errors. You may need to try more than one method before you're successful.
Download the (The Specific Error Code Is 0xc0000185) repair tool. avg-linkscanner-verisign-safe.jpg Install the program and click on the Scan button. Fix any errors it finds once the scan is complete. Restart your computer.
• Manually edit your Windows registry. Start the registry dditor by clicking the Start button, typing regedit in the Search box, and pressing Enter. Open the HKEY_LOCAL_MACHINE folder ==> "Software" folder ==> "Microsoft" folder==> "Windows" folder ==> "Currentversion" folder. Click on the Run folder ==> Click on the The Specific Error Code Is 0xc0000185 file. Delete the file by pressing Delete The Specific Error Code Is 0xc0000185 key. You can then reinstall the file on your PC
• Update the drivers for the device. It's possible that installing the latest drivers for the device could correct the error. If this works, it means that the existing drivers you reinstalled in the step above may well have been damaged.
• You can also download the Windows The Specific Error Code Is 0xc0000185 recovery utility which has proven successful at fixing this error..
Feb 17, 2014 | Samsung Computers & Internet
Error 0xc0000185
A 0xc0000185 error is usally a regestry error and there are two possible fixs, 1 is to reinstal windows or if you have a system reserve partiton you can resore windows with that both of these may and proberbly will lead to data loss, 2 is you can use a registry repairing program such as CCleaner to repair the registry,
Good luck ;)
Oct 19, 2013 | Acer Aspire 5315 Notebook
My thoshiba e-studio 352 giving an error "latch the developer unit". Please help to resolve this issue. Thanks Roy Robinson
I think the cable is not connected properly on the developer unit...Open front cover, take out the waste toner box, and u will see the connector.
Oct 02, 2013 | Toshiba e-Studio 350 Copier
Code error 0xc0000185
Follow these steps
First you should Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including BSODs.
- Restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in safe mode then update your graphic drivers from the manufacturer site of your laptop
Let me know if it helps you.
Use system utility tool like RegInOut to remove unwanted files , fix registry and windows errors which causing blue screen
Jul 03, 2013 | Sony VAIO Computers & Internet
Gateway laptop error
Which operating system ?
Restoring your Windows 7 Gateway computer to its original factory settings is a great way to get rid of pesky viruses you can't seem to remove from your computer, or simply to remove old programs and files from your computer and start with a clean slate.
Your Windows 7 Gateway computer will likely run faster as a result of deleting old and unnecessary files.
It's also a good idea to restore your Windows 7 Gateway computer to its original factory settings if you plan on selling it, or passing it along to a family member or friend.
Recover From Windows 7 Home Screen
Click the "Start" icon in the lower-left corner of your Windows 7 home screen.
Click "All Programs" in the Start menu, then click "Gateway".
Click "Gateway Recovery Management" to open the Gateway Recovery Management program.
Click the "Restore" header, then click "Restore System To Factory Default".
Click "Yes" in the "Confirm Restoration" dialog box, then click "Yes".
Click "OK" in the dialog box warning you that all of the personal data on your computer will be deleted. Your computer will automatically restart.
When your computer restarts the restoration process will begin. The process could take anywhere between 30 and 90 minutes.
Click "OK" when a dialog appears telling you that the computer has been restored to its original factory settings and that you need to reboot your Gateway Windows 7 computer.
Your computer will reboot.
After the computer restarts you will need to configure Windows 7 with your personal preferences.
Recover at Startup
Turn on or restart your computer and hold down "Alt" while clicking "F10" during startup until you are redirected to the Gateway Recovery Management program.
Click "Restore System From Factory Default".
Click "Next" to begin the restoration process.
or if still no joy
http://www.almuseo.com/download-repair?Windows 7 0xc0000185for Windows 7 0xc0000185 and associated problems.
Windows 7 0xc0000185 error message codes are almost always caused because of missing system files inside your Microsoft Windows operating-system.
When you've got Windows 7 0xc0000185 error message then we suggest that you perform an error scan.
This article provides related information that explains the best way to repair your Windows Windows 7 0xc0000185 error codes either by hand and automatically. Additionally, this guide can help you to fix most regularly occurring error code messages connected with Windows 7 0xc0000185 error code which you might possibly get.
Jun 03, 2013 | Computers & Internet
O error 0xc0000185
This error can occur when there is a problem in reading and/or verifying data on the HDD/SDD. The most common cause is a loose data connection, although the power connection can cause similar issues. Check the connections at both ends of the cables. Also check the connections to your optical drive and make sure that your RAM is correctly seated. Since you have already opened your laptop to do prior maintenance, it is quite possible that you have dislodged one or more cables without realising it. By the sounds of it, your laptop continued to work for a short while before failing again with your current issue. It is likely that a sudden sharp knock might have caused a loose connection to become disconnected.
Apr 23, 2013 | Acer Computers & Internet
Computers & Internet Logo
2,168 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
