Ricoh MAINTENANCE KIT TYPE 6330N Maintenance Upgrade Kit Logo
edwin Posted on Mar 19, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to clear the error replace maintenance kit
How to reset the error message replace maintenance kit on nashuatec 6330 printer
Freckled legs
Level 2:
Habit-Forming:
Scholar:
  • Ricoh Expert 129 Answers
  • Posted on Jun 03, 2014
Freckled legs
Ricoh Expert
Level 2:
Habit-Forming:
Scholar:
Answers
129
Questions
0
Helped
105236
Points
252
In service mode:
SP7804
7804 1 Paper
7804 2 Transfer Roller
7804 3 Paper Feed Roller
7804 4 Fusing Unit
Take note:
SP5930 001 Meter Click Charge
[0: No] default
This setting is for machines where the operator is responsible for replacing the Maintenance Kit.
(PM counter resets automatically after the user replaces the fusing unit.)
[1: Yes]
This setting is for machines where the service technician has responsibility for servicing the machine.
The service technician must reset the PM counter after completing machine maintenance.
3helpful
I just replaced the Fuser Kit on the Office''s HP 5500 laser color printer but the error is still there and as in the instructions I never received the question: "Is this a new fuser...
Here is the instructions to reset the fuser maintenance count:
HP Color LaserJet 5500/5550 Maintenance Code Reset Instructions
  1. Press the ? button until the display reads "CONFIGURE DEVICE" and press ?.
  2. Press the ? button until the display reads "RESETS" and press ?.
  3. Press the ? button until the display reads "RESET SUPPLIES" and press ?.
  4. Press the ? button until the display reads "FUSER" and press ?
This should reset your printer and clear the error message.
I hope this helps, if so please rate my solution,
BuddyMc
How to reset hp laserjet m5035 maintenance kit problem
When page count approaches 200,000 pages printed, the device alerts to order a maintenance kit. The message can be temporarily cleared by using the Clear Maintenance Message item on the Resets submenu under Administration. When the page count reaches 200,000, the message can no longer be cleared and the maintenance kit must be installed. To check the number of pages that the device has printed since new maintenance-kit components were installed, print either a configuration page or a supplies-status page. The print-engine maintenance kit includes the following items:
  • Fuser
  • Rollers (transfer, feed and separation)
  • Separation pads
  • Installation instructions
1helpful
Where is the maintenance kit on hplaserjet 4345mfp
After printing 215,000 pages, the MFP alerts you to order a maintenance kit. The message can be
temporarily cleared for approximately 10,000 pages by using the CLEAR MAINTENANCE
MESSAGE
item on the RESETS submenu. When the page count reaches 225,000, you can no
longer clear the message and you must install the maintenance kit. To check the number of pages
that the MFP has printed since new maintenance-kit components were installed, print either a
the maintenance kit is Fusing element , pickup rolls for all trays, and transfer corona
To reset the maintenance-kit counter
Turn the MFP off and then on.
2 When the memory count appears on the control-panel display, press and hold 6 until all three
LEDs flash once and then stay on. (This might take up to 20 seconds.)
3 Release 6 and then press 3.
4 Press 6 to select NEW MAINTENANCE KIT.
5 The MFP completes its initialization sequence. The maintenance-kit counter is automatically reset.
16helpful
5answers
How to clear error code,sc542 nashuatec photocopier-mp6500
01. Press Clear/Stop Key (Yellow key) 2 tram
02. type 107
03. press Hold down Clear key 5 secend ( Red key)
04. type 5 and press # or Ok
05. type 810 and Press # of Ok
then machine Of and On
3helpful
2answers
80 scheduled maintenance
This issue is just like changing your oil or the timing belt on your car. If you don't fix it correctly it leads to other problems. So, be warned. :+)
Here's what the Lexmark KB says:
On the Lexmark T520/522 series printers, we recommend that the maintenance kit be replaced after every 250,000 pages. If possible, an authorized service technician should replace the maintenance kit parts on these printers.
On the Lexmark T620/622 series printers, we recommend that the maintenance kit be replaced after every 300,000 pages. The maintenance kit parts for these printers are customer-installable, but some dismantling of the rear area of the printer is involved.
Note: The maintenance kit may need to be replaced more often if the customer is running heavy media (like card stock or labels) through the printer.
It is possible to clear the maintenance error message without replacing the kit. The printer will still operate, but some print quality problems may arise. However, this is not recommended as the message serves as a reminder that maintenance is due. If the printer is under warranty, the customer has to purchase the maintenance kit and have it replaced in order to keep the warranty active, although the on-site replacement itself may be covered under the warranty.
The parts that make up the maintenance kits are:
A fuser unit
A transfer roller
A charge roller
To find the part number of the maintenance kit needed for your printer, see Printers / Maintenance kits.
Clearing the maintenance message
To clear the message, you will need to go into the printer's configuration mode. Do the following:
  1. Press and hold the SELECT and the RETURN buttons as you power the printer on.
  2. Hold the buttons for six to eight seconds after turning on the power, then release them. (If you receive the maintenance message, press the Go or the Select button to continue past it.)
  3. Now, press the right Menu arrow until you see RESET MAINT CNT.
  4. Select this. You may need to press the Select button again. The printer display should briefly flash SAVED.
  5. Power the printer off and then back on in the normal way. The printer should now power up normally.
  6. If it does not and the error returns, repeat the above procedure.
2answers
Nashuatec P7132N "Replace printer cartridge" after refill
Greetings
I want to see what types of inks used for the printer nashuatec P7132n
Thankful for your cooperation
Ashraf Dora
[email protected]
28helpful
2answers
Lexmark x642e MPF Reset maintenance counter
Hi~
You can reset the maintenance count by going to the Configuration Menu.
Step 1: Turn off your X64x printer
Step 2: Hold the 2 and 6 buttons while the printer is off
Step 3: Turn on the printer but don't release the buttons yet. Keep holding those buttons for about 10 secs
Step 4: On your Operator Panel, you should see "Configuration Menu"
Step 5: Scroll down and look for "Reset Maint Count" and select it.
Step 6: Exit Config Menu and powercycle your printer (turn it off then back on)
Hope this is helpful... =)
<<ichtuscheeky>>
2helpful
4answers
Ricoh ap4510 - Maintenance Kit Issue
For the message to be cleared you should enter the service menu and reset the replaced elements
Getting an display in the printer.
If you have the manual there is probably a section about this. It does sound like some parts may be wearing out and the printer is asking for new ones. Check out this link: http://www.printertechs.com/tech/maintcount.php A snip from the info there: If the display panel on your HP laserjet reads "perform printer maintenance", "perform user maintenance", or anything along those lines it means your printer needs a preventative maintenance kit, which includes a fuser and various rollers. Once you have installed the maintenance kit the message will only go away if you clear the maintenance count. For example the laserjet 4000 has a 200,000 page maintenance interval. Once you reach 200,000 pages the error message appears and you need to reset the maintenance count to zero to make the message go away.
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
