Question about Sunpentown Cooktops
Looking to replace a broken glass covertop for a Magnetic Induction hob
My ceiling gave in and fell on top of my fairly new Induction Magnetic hob glass cover top and broke into pieces. I need to replace the glass cover top because the stove is still working. Please help me locate where I can purchase a cover top for a 4 plate Induction magnetic hob.
Posted by MD Murahwa on
David Ellis Rhea
  • Sunpentown Master
  • 3,462 Answers
I looked up your cooktop and discovered it to be made by Frigidaire.
Hence & therefore, try the website "searspartsdirect" and see of they will give you schematics to buy the parts for your needs.
God bless your efforts.
Posted on Mar 06, 2018
5 Related Answers
Anonymous
  • 93 Answers
SOURCE: Gagganau Glass Cooktop
www.foxatlanta.com
Posted on Jul 21, 2008
SOURCE: Ceramic Glass broken
when ordering you would have to know the color also
Posted on Dec 06, 2008
Cbreezer
  • 3 Answers
SOURCE: jenn air cook top
Yes you can. Call Jenn Air ((877) 232-6771) and give them your model number (serial is helpful too). They sent my replacement glass within a week. I have a model JED8430ABD from 2000 and they had the top. Fit perfectly and took about an hour to replace.
To change it out, after unplugging the cooktop, I removed the metal tape connecting the external vent shaft to the blower. Then I just lifted the entire cooktop out up out of the countertop so I could access the screws on the sides of the cooktop (looking at the edges of the new cooktop glass helped me figure out which screws to remove around the edge). Then I removed the 2 screws in the vent area on top (1 black screw on each side). And that released the cooktop glass from the metal box that holds the burners. I then took the rubber rings out of the knob holes so I could put them in the new cooktop (I almost missed that...). Finally, I put the new cooktop glass on, put the screws back in, lowered the cooktop back into the counter, and retaped the blower to the vent shaft. Voila!
I really wouldn't be afraid of doing this yourself if you are handy at all. And it will save you a ton. Good luck.
PS The screws around the perimeter are hexigon shapped, so you can't just use a screwdriver. I found my Black & Decker electric screwdriver had that same shaped hole that it held the bit, so I just pulled out the bit and used the screwdriver that way. Worked like a charm.
Posted on Mar 16, 2009
Maytag317
Victor
  • 1136 Answers
SOURCE: TOUCH CONTROL HOB (SCHOTT CERAM) GLASS CRACKED
Hi. Yes you can buy a new glass. Most of the come with frame top now. If you get me the model # I can look this up for you and get you an idea on cost.
Vic
Posted on May 18, 2009
Anonymous
  • 42 Answers
SOURCE: Magnetic contol on Induction hob is very eratic,
your induction hob reqs.,special induction pans to make them work correctly.
Posted on Sep 28, 2009
Rangemaster Professional Plus 110 induction. How do I lift glass hob cover to replace Hob display module
I believe you will find your answer on this site. In reading how someone else did it, some of the screws appear to be quite well hidden.
http://www.ukwhitegoods.co.uk/forumsphpbb3/removing-hob-rangemaster-110-t23376.html
Dec 19, 2017 | Rangemaster Cooktops
Hob ceran replace with new induction hob
Need looking at by NEFF , a big job .
Mar 16, 2015 | Neff Cooktops
Hotpoint induction hob wont turn on
Check power supply at socket or meter box. Make sure that the circuit breaker hasn't tripped. Also, induction cooktops wont heat without induction cookware. They must be steel. Glass cookware wont work on an induction cooktop.
Jan 03, 2015 | Cooktops
Replacement glass top miele KM5773 36
THERE ARE SEVERAL WEBSITES SELLING MIELE
parts: Search them and contact them:
Technical Service
Miele Parts Partmaster
Find Miele Spares and Accessories
Accessories
Expanda your search with google, use terms
MIELE PARTS
Apr 10, 2013 | Miele "KM5773 36"" Ceran Glass Induction...
I have broken the glass on my induction cooker
ENr is on rating plate on bottom of hob. The Ceramic top is easy to replace, it is held on by 3 pozi screws on each side (12 altogether) and just sits on the main electrical parts, obviously the unit should be isolated from main before you remove the top. Part can be ordered using the link
http://www.bosch-home.co.uk/store/spareparts/search
Mar 16, 2013 | Bosch Cooktops
Glass on neff t4243 induction hob has cracked
hi,
is it possible to replace a cracked glass on my Neff induction hob?
where would I get the glass for my Neff induction hob replaced?
is it very costly?
the model number is t4483x2/09
Feb 28, 2012 | Cooktops
Burnt induction hob
hi my name is mark, you can try softscrub or a glass cook top cleaner made by jenn- air or a genaric brand from the supermarket.
Mar 01, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Induction hob switching off
check that the hob is wired correctly underneath 1,2,3 should be linked together as live 4,5 as neutral and earth takes its place as earth,
if it is wired correctly then i m afraid the hob needs a new induction element it is all one complete unit on these hobs not seperate so your looking at £1000 + to fix it plus engineer call out charges
Dec 06, 2008 | Kuppersbusch K 23 in.EKE604.2 Electric...
Cooktops Logo
342 people viewed this question
Top Sunpentown Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a Sunpentown Cooktop Expert? Answer questions, earn points and help others
