Bosch Logixx WFT 2806 Front Load Washer/Dryer Logo
Jeannine Posted on Mar 19, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
There is power to the machine but it will not start
prem mathew
Level 3:
  • Bosch Master 662 Answers
  • Posted on Apr 13, 2013
prem mathew
Bosch Master
Level 3:
Answers
662
Questions
Helped
265266
Points
1748
Power on, press the start button for 5 or 6 seconds, the key sign will go off. Perhaps your machine was accidently locked.
Helped?
2answers
Maytag 4000 series washer won't start, once you press the start button machine power off..
Power off means a short circuit. Either the PC controller board has a defective part or the safety electronic / shut down protection has indicated a fault and opens to prevent a fire, electrical damage, or other condition.
My Bosch 1244E will not go on I plug it and no power?
Washing Machine Won't Start - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jun 21, 2013 - If wall socket & fuse are OK but washing machine won't start ... didn't work - so I tried plugging my Hoover washing machine into another plug and all systems are go! ... I have a bosch washing machine which is 16 months old.
Washing Machine Fault Diagnosis - How to repair
www.how-to-repair.com > Home > Washing machines
Nov 11, 2014 - Washing machine will not start, no power. ... So begin at the plugand make sure that there is power to the socket and that the fuse is okay ... I have aBosch washing machine which is leaking from underneath and the water is coming out the front at the bottom. .... It washes but won't go into rinse or spin.
Washing Machine Will Not Start - What To Check - How To Fix
removeandreplace.com/.../washing-machine-will-not-start-what-to-check...
Apr 10, 2015 - Be sure the washer is plugged into the electrical outlet in the wall. ... If the lid switch is faulty, then the washing machine will not start. ... If the lid switch is being pressed but no power is being supplied to the washers motor, ..... October 28, 2014; Bosch Washing Machine Error Fault Codes October 28, 2014 ...
Dishwasher Will Not Turn On - How To Fix ...
1helpful
Hoover 700 LA keeps overflowing
Hi just read you posting.Now fortunately I have the same machine.Just a couple of questions.--1-- does the machine flood at the start of the cycle when it is filling for the wash or in the rinse cycle? 2---At anytime while it is filling does it start to wash? Now try this for me, Turn the machine on at the start of a cycle so it starts filling and then when you hear the water going into the machine turn the power off at the power point. After you turn the power off at the power point can you still hear water coming into the machine?Please reply with additional information to the questions because with those questions answered I will tell you the exact fault and guide you throe the repair.
1helpful
Machine will not start, power is on but machine
suggest you check the door lock mechanism. If it is not latching correctly when the door is closed,the program will not proceed.
Door light no working so machine will not start
check power is getting to machine with suitable electrical screw driver.to do this remove top from machine and check live wire just inside rear of machine. fault could be door lock if you have power in machine
I push the start up button and no start up
Check the power cable and ensure the power supply to the machine. It might be a connectivity problem at your Power board or in the Power switches in your machine. If both are perfect then you need to check the motor.
1helpful
Laptop will not turn on even though LED flashes
Remove the battery and the power cord, wait 5 minutes and put the power cord in and try and start it. If it starts shutdown the machine and try the same test this time put the battery in aswell. If the machine starts fine you will be ok, if it doesn't start with the battery in then you may need to replace the battery.
1helpful
Clear Memory
hi there!
Try a hard reset. This trick usually works with Lexmark Fax machines.
Disconnect the power cord. Hold down the power button and connect the cord (Power Switch ON) while holding the power button. Most models would substitute the power button with START. so Hold the START button in this case.
Hope this helps!
-levibit-
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
