SHOWS FULL MEMORY AFTER TAKING 1 PICTURE
SOURCE: JVC D3370U wont record to memory card (school project HELP!!!)
You have an option switch "MOVIE or STILLS", choose still option to take stills in your SD card. Yes you can freeze frames while viewing the downloaded contents from the computer, for which you need to work on video editing software, like MOVIE MAKER which is a built in application with Windows XP.
SOURCE: Memory card
When you use an SD card in mulitple cameras, each camera creates it's own folder beneath the DCIM folder. I'm not sure if you have a program that automatically opens when you insert the SD card in your reader, but perhaps you can try double clicking on "My Computer" and locating your reader/SD card and opening that folder manually. Once you're there, open the DCIM folder and see if there are multiple folders inside. Open each one to see if you can locate your pictures.
If you have a program that opens automatically when you insert the SD card you'll need to figure out how to tell it to look in other folders.
SOURCE: what size SD card does my video camera (JVC GR-D395u) support?
Your camera does support SDHC and all it's capacities.
SOURCE: memory format problem
First of all, check the lock button on the side of your sd card to make sure it's not in the lock position. If it's unlocked and you still cannot format the card, you can always format it on your computer via usb.
SOURCE: How to use an SD card to record on a JVC GR-D370 mini DV?
Download PC Inspector File Recovery.Thank
