Question about Kenmore Sewing Machines
The Feeder Dogs are not moving forward or backwards on my sewing machine.
I have a Kenmore Sewing Machine (Model #385.16221301 -- Serial #74152057). I was sewing along and then the Feeder Dogs stopped feeding the material through. The Feeder Dogs go up & down, but do not move forward or backwards. How can I fix this?
Posted by Suzanne Travelstead on
sylviaivie
  • Kenmore Master
  • 1,564 Answers
Are the Feed Dogs dropped? Check your manual for the location of the switch. .... otherwise your mechanism has been compromised. Take it in for repair.
Posted on Mar 20, 2013
2 Related Answers
SOURCE: The feed dogs will not move the material
check the feeddogs & see if there in the up position, if there not move the lever or knob to the up position
if the lever is up then there is something wrong with the feeddogs & it needs to be serviced
Posted on Jan 31, 2012
Zenqi
Paul Howell
  • 208 Answers
SOURCE: started sewing backwards now not moving material at all
Sounds like the machine's age is causing the lubrication to get sticky.
Try changing the pattern by moving the pattern selector around.
Take out the bobbin and remove the thread and presser foot, raise the presser lever, set the pattern to zig zag, set the stitch length to maximum and run the machine at full speed. While it's running, repeatedly press the reverse lever all the way down. Run it for at least a few minutes.
Posted on Nov 14, 2009
Problem with feeddog on my sewing machine
When the feed dogs have been dropped, some machine feed dogs will not become activated (rise & move backward & forward) until stitching is begun.
Be sure the stitch length is set high enough to actually cause the feed dogs to move forward & backward.
If they still do not move and your machine is mechanical (not computerized), the old oil may have solidified and is preventing them from moving. A good cleaning and oiling may be required. Other than that, it may need service.
Aug 26, 2016 | Sewing Machines
Fed dogs will not move fabric
hi, do a web search for feed dogs and put the make and mode lof your sewing machine in there along with the words how to adjust or how to repair....it should throw up loads of results
Jul 03, 2015 | Sewing Machines
My machine will not move forward.
Sewing machines have a "free sew" that allows you to move a hoop by your own choice any way you choose. This means the feed dogs are below the plate and will not move the material forward or backwards either. You need to find the button and switch it to feed.
Dec 08, 2014 | Sewing Machines
The feeder plate isn't working. how do I fix?
here is a link for a free manual see if it has the information in it
about the feed dogs, some machine have a lever to adjust the
feeddogs and some don't
http://www.singerco.com/uploads/download/864_white-970,972,979-x-.pdf
Dec 02, 2012 | White Sewing 979
Started sewing backwards now not moving material at all
Nov 14, 2009 | New Home MX-3123 Computerized Sewing...
My kenmore 385 won't feed fabric
Check to see what pattern is selected. Be sure it isn't the buttonhole.Select straight stitch.Move the stitch length setting to 4.Turn the handwheel and see if the feed dogs move forward. Press the reverse lever and see if they move backwards. Select straight stretch stitch and turn the wheel to see if the feed dogs move forward and backward.Check the presser foot release on top of the machine and make sure there is pressure on the foot.
Sometimes the reverse assembly on this machine stops working because it has the wrong type of grease on it and it turns into a hard gummy mess that won't let it work.
sewman7
May 14, 2009 | Sewing Machines
Kenmore Model (385.15108200) Fabric not moving
hi! there if your feed dog does not move the fabric forward or backward,if this is so try to run machine w/o the fabric check if feed dog move on cycle,the teeth should be moving upward and downward rotation pushing action on your fabric,the teeth should come out to the plate slot of feed dog.if not adjust upward, and adjust also the presser foot of needle.if your feed dog is not moving when machine running,thre is a mechanical disengage or loosen in shuttle assymble and feeder dog mechanism they link together ubder the machine,as the shuttle move on one stroke the feeder also move also with the needle.Chesk the adjustment and link mechanism.in addition to this try to clean feed dogs by brush chips thread and fabrics sometimes stored on mechanism of feed dogs and shuttle.
Mar 19, 2009 | Kenmore 15208 Mechanical Sewing Machine
Dropping Feed dogs on kenmore model 19233
Pull out the removable table and you will see the drop down feed dogs switch lever behind the back of the machine. Move that lever to the left or right to have feed dogs go back to normal sewing mode OR for embroidery mode.
Sep 20, 2008 | Sewing Machines
Kenmore sewing machine # 385.17626 feed dogs not advancing fabric. Appear to move up and down, but not forward to back.
I had the same problem and had recently posted my own message, with no replies. Took it to a repair person and he fixed it at no cost - it was stuck in reverse because the mechanism(s) were all gunked up. Take off the accessory box on the machine and the bottom plate. move the mechanism so they move freely and take out any gunk you see. The feeder dogs should now move back & forth in addition to up & down, feeding the material properly
Jun 21, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Sewing Machines Logo
451 people viewed this question
Top Kenmore Sewing Machines Experts
Irene Tulloch
Douglas Plant
Douglas Plant
tsalagi152
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
